Cooling fan issue?
    Cooling fan issue?
    So my car is still overheating when I drive in traffic/let it sit, and I've gotten all the air out of my system.
    Also, my radiator fan still doesn't seem to turn on while the car is on, but seems to turn on after I turn off the car.
    Could the radiator fan switch be an issue?
    I'm completely out of ideas.
    You should get a manual and follow the instructions for troubleshooting fan issues. Park the car, turn it on. When the temp. gauge reaches half way the cooling fan should turn on (assuming its not 5F outside).
    If it does not come on you are looking to test the relays, temperature sensors and other items which could cause it to not come on.
    If the fan comes on (I suspect it will as it comes on when you park the car), then you are looking into other things causing the over heating. Bad radiator, blocked coolant passages, air (although you said you did this), bad head gasket, improper coolant flow.
    Good luck.
      Raf, would it be safe to say that the sensors are fine, seeing as how the fans turn on after I've stopped the engine?
        I would still test it though as I'm not sure if there are different sensors in use for car on/off states.
          Yeaaaaah.
          So it turns out the sensor in the thermostat housing was in fact bad.
          Thanks for the help.
