h22 turbo kits?
    h22 turbo kits?
    hey everyone. im new to this site. and i was wondering what turbo kit to buy for my jdm h22 swapped cb7? ive been searching around and couldnt find anything about what turbo kit to buy. will the h22 turbo kits for a prelude work? will it just bolt in? sorry for the noobie questions. but i want to turbo my accord. i found a really good tuner in my area and plan on boosting my stock jdm h22 and getting it tuned on maybe 8psi. but i cant figure out what turbo kit to buy for it. any help would be helpful. thanks everyone. this sites exactly what i needed to find. a site dedicated to my accord. haha.
    Don't get a kit. Learn what each part does and build your own setup. Any pre-made kits are going to be junk, or overpriced. Or, very likely, overpriced junk. Get your own parts and do it right.
    I suggest reading Maximum Boost by Corky Bell, and Honda/Acura Engine Performance by Mike Kojima. Those two books will give you a decent understanding of turbo systems.
    Boosting a stock H22 is always risky. It's a good thing that you found a good tuner... that shows that you understand the importance of tuning... but be SURE he knows how to tune a turbo H22, and be sure you get whatever setup he's comfortable with (like a P28 ECU running Crome, etc...) Even with a good tune, you're boosting a high-compression engine that's at least 10 years old, with internals that were never intended for turbo. You CAN do it... but if this is your only car, and something you rely on to get to work or school, you might want to look into something else. Either don't boost the H22, or get a beater to get you around... so you don't rely on a car that may pop at any moment!
      deev is right. most kits are is overpriced junk. and in my opinion if youve got the luxury of an h22 you should go n/a. maybe put a good shot of nos and build the motor a little bit. this could be potentially safer for the motor.
      Soon to have the first *Bottle Fed Accord* in MI!
      Vouch For: fatboy1185
        or if you were to piece the setup together yourself then at least do a few things to the motor, maybe some low compression pistons and some new rods. make sure the tuner is reputable and like deev said and have him go with a ecu/tune he's comfortable with. if this is your daily driver get a beater as a back up because things have a good chance of breaking when you add boost into the mix.
          thanks guys. im going to go read up on it. and probably piece one together now that you guys mention it. and yes i do know that tuning is a key process when building a motor. ill do what you guys mentioned with the ecu too. most likely be going with crome. but thanks for the help guys. and another question. what parts do i look for the turbo kit for? like prelude parts or accord parts or mix and match? but if i dont decide to piece one together...what kit should i buy my turbo for, accord or prelude? i dont know because its a prelude motor in an accord.
            Look for a manifold that will fit the H22. Other than that, there are no specific Accord or Prelude parts.
            Don't think in terms of kits. Think in terms of parts.
              oh ok. so I'm going to guess, but I can buy all turbo parts for our year accord minus the h22 manifold. Since the charge piping is set to be in the accord? Not positive but just throwing it out there I'm kind of familar with turbos but not really. My friend knows a lot but not much hseries and accords. But he does know turbos. So I'll prolly ask him about stuff.
                You'll have to piece together your own charge piping. Even a "kit" would probably just come with piping that you could alter to fit as you desire.
                Honestly, there really are no "Accord specific" turbo parts.
                  get piping of desired diameter and weld your own shit. lol.
                    oh alright. thanks guys. I'm gonna figure something out. probably find someone else with a turboed c#7 and buy parts from them or ask where they got there parts from
                      Weld? Feh... hose connectors and clamps. Though welding WOULD be better...
                        I heard with constant temp changes under the hood, metal will flex and eventually crack and break the weld
                          idk, if this was a problem then our exhaust pipes and shit wouldnt be metal would they?
                            pvc pipe FTW! lol jk
                              haha. alright. ill figure something out. thanks guys for the help.
