View Post
h22 turbo kits?
Originally posted by hseriesaccord View Postthats good to know. but mostlikely going with the mahle pistons if i decide to build the motor more. any advice on what rods to use?
Eagle rods aren't hardcore... but they should be fine for a mild setup. Rod strength isn't quite as important on a turbo motor (until you go crazy) as it is with an NA motor.
If you buy on ebay, just be sure you're buying from a reputable seller. I don't know of anyone selling knockoff pistons or rods labeled as brand names... but if they're out there, the "too good to be true" pricing is where you'll most likely find them.
Originally posted by deevergote View PostEagle rods aren't hardcore... but they should be fine for a mild setup. Rod strength isn't quite as important on a turbo motor (until you go crazy) as it is with an NA motor.
Originally posted by reccakun08 View PostHe is obviously not ready to build his own turbo kit and all you guys are just giving him bs general answers. judging from his post he wants to boost and tune for 8psi which is absolutely retarded. To be honest if you want to turbo it just get a kit since your knowledge seems fairly low. There are a lot of questions you need to ask yourself.
1-Budget: How much are you willing to spend?
2-Power: How much power do you want to make?
3-Motor capability: Currenty condition of motor with the addition of boost?
4-Tune: Although you said you have a good tuner in your area what does he use to tune? what are you planning to use stand alone/piggy back/ecu rom?
A kit is very simple and straight foward usually everything you need and already setup for a user. However they usually are expensive and arent very efficient. When you buy a kit it usually is what it is. When you are custom planning your own you need to know what power, what size turbo and what boost level to be efficient, what manifold are you going to use, what injector size, what are you using to tune, whose installing, can your current motor without a rebuild handle the extra power, etc...
Soon to have the first *Bottle Fed Accord* in MI!
Vouch For: fatboy1185
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
Originally posted by Djmoua View PostSounds like a scam artist trying to get him to buy stupid shit.
later.
haha. don't worry, no offense takin. and yes I'm trying to do it right the first time around. even if I'm trying to boost a pretty much stock motor. ive heard of plenty of h22s being boosted stock at 300hp. I mean I migt not get lucky and get that goal reliably. but I do plan on trying to be safe as possible when doing it. I don't want to blow the motor as soon as I get it turboed. I don't plan on cutting any corners and hopefully I can reach my desired goal. I have been readin a lot about it and trying to figure out a safe way to do it. so hopefully I can make it happen.
Originally posted by hseriesaccord View Posthaha. don't worry, no offense takin. and yes I'm trying to do it right the first time around. even if I'm trying to boost a pretty much stock motor. ive heard of plenty of h22s being boosted stock at 300hp. I mean I migt not get lucky and get that goal reliably. but I do plan on trying to be safe as possible when doing it. I don't want to blow the motor as soon as I get it turboed. I don't plan on cutting any corners and hopefully I can reach my desired goal. I have been readin a lot about it and trying to figure out a safe way to do it. so hopefully I can make it happen.
thanks. I was planning on doing that too. Hopefully I can get the build going during this wintrr time. And get it tuned after winter. Don't worry I still do have a bunch of friends that's willin to drive me anywhere most of the time. Specially since I've done it for them while they were bulding there engines. My friend just got done rebuilding his 2.0 liter ls-vtec turboed eg. I was driving him around everywhere while that was going on. And he got a new bigger turbo. He got the garret gt37r. His car was already fast. Now I'm it even faster. Hes one of the people that are going to help me piece together the turbo. He now has a beater car though. So he'l use that too drive me around. Plus I got plenty of other friends. So I should be good for the time being while I'm putting the turbo together.Last edited by hseriesaccord; 11-23-2009, 04:24 PM.
