looking for a good throttle body for my f22a1 is the a6 the only one.
Throttle body
Originally posted by 19TcappaLX View Postlooking for a good throttle body for my f22a1 is the a6 the only one.
Originally posted by jdm92_accorn View Postit's not worth it unless you're swapping to a h23 intake manifold. the biggest accord throttle body is only 52mm and the h23 is 60mm and if you can get one an acura integra type-r throttle body will bolt directly on and it's 62mm.
So the H23 is the best option.
member's ride thread
91 Accord SE 176k
You have a few options to achieve similar goals.
1) Swap a F22a6 throttle-body (TB) and intake manifold (IM) setup onto your F22a1 motor.
2) Swap a H23ax TB and IM setup onto your F22a1 motor.
3) Have your F22a1 TB bored by www.maxbore.com.
NOTE: The F22a6 manifold and H23ax manifold have better flow characteristics than F22a1/a4 on a stock or near stock motor setup.
well i'm doing a H23A Intake manifold swap, and i need a throttle body can i get a h22A TB if ican't fing a h23 one?...
Originally posted by deevergote.......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
Originally posted by Granite CB7 View Post^Yes, an H22 t/b could replace the H23 t/b no problem.
rEAL TALK
`my thing is in my A1 i dont have a black box but i do want to run a full h23 manifold from top to bottom would i still need the black box to make the setup work perfect and on the throttle body there a extra top map sensor do i remove it and get a weld or should i plug it..and hope for no codes" its just a single cam "
is bigger always better for TBs?2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
Originally posted by theSOB View Postis bigger always better for TBs?
Originally posted by pedroalcala View PostIf going aftermarket for a bigger TB you are sure in hell going to kill you gas milage...Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
Originally posted by foamypirate View PostCare to explain? Or are you just spouting something you heard someone tell someone else that one time in this other thread on this other forum?
