Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Old 04-16-2019, 12:11 PM   #1
G. Wiffington
Wish more people had a Euro-R
I wish more people that were active on here had Euro-Rs. I see that people say
that they are basically the same as the baseline H22 but there are some things
that are not the same at all & I just want more people to talk it over & confirm
it with.
I read on HT that apparently when people put a euro intake manifold on a
regular H22 they have to "modify the injector ports". Is that because they mate
up differently at the head?
I wonder since the Euro's injectors are longer, does the base H22 injectors not spray
as they should?
This was from the thread " the R manifold runners at the flange do not have an arch that comes up around the pintle of the injector.
the stock R injectors have a much longer pintle and therefor reaches the end of the flange without a disrupted spray pattern.
well the stock h22 injectors has a very short pintle. if you were to leave this area alone without porting the fuel spray pattern would
completely be disrupted and cause a drip instead of a spray into the combustion chamber. "
I know that he was talking about porting the Euro IM so it would mate to the base H22 correctly but, what did he mean when
saying about the spray pattern difference in using the stock H22 injectors will cause a "drip"?
I'm guessing that since the Euro injectors are much longer so they reach the end of the flange for the IM as it should,
while the H22 injectors are shorter which would result in them not reaching the end of the flange.
When I went through tuning my car it always seemed on the rich side, so I
am curious if that if the reason why. Due to the spray pattern & shorter
pintle on the stock base H22 injectors.
What do you guys think?? My Euro runs great but, I just saw this thread &
was curious about what you guys think.
Old 04-16-2019, 12:27 PM   #2
G. Wiffington
well sometimes you gotta keep reading lol..
I saw in the same thread someone asked about running the obd1 injectors &
they said it ran fine just as I am experiencing.
I wonder if I could be gaining anymore power from the Euro Injectors?
Old 04-16-2019, 09:59 PM   #3
SSMAccord
I think the concern about the fuel spray pattern concerns the shape/length of the dispensing end of the injector. The Euro-R injector is longer extends past the shrouded area in the flange.
The USDM injector has a conical shape if I am remembering correctly. I think the end is also a shorter which leads to a concern with the pooling of fuel that creates the drip. The Euro-R injector has a much more slender form factor than the USDM H22 injector.
I have access the stock Euro-R fuel injectors, but the normal H22 injectors are in my engine so I can't really compare them at the moment.
Old 04-19-2019, 03:51 PM   #4
G. Wiffington
Thanks for the input. I do have a set of F22 injectors & the Euro's side by side.
DO you know if the H22s are close the to the size of the F22s?
Euro R Injector on the Left | F22 Inector in the Right
Old 04-19-2019, 03:54 PM   #5
G. Wiffington
So you have a Euro right? I think we talked before about them.
Are you running the Euro H in your car? I am running the base H22 injectors
& have never had an issue.
Old 04-19-2019, 05:37 PM   #6
Rilas
The stock injectors for the F22 are physically the same size the H22 injectors. Just the H22 injectors flow more.
Old 04-20-2019, 04:39 PM   #7
'93CB7Ex
Foundation Member
idk much about the engine, but when they are 25 years old, i want the car lol.
COUPE K24
Old 04-20-2019, 05:20 PM   #8
sonikaccord
I had a Euro-R manifold in my Lude.
The spray pattern is different, requiring "opening" of the fuel injector hole/shroud/thingy.
YouTube Clicky!!
Old 04-21-2019, 01:49 AM   #9
af_1132
af_1132 is cool... so far.
Send a message via Skype™ to af_1132
Those Euro R injectors look identical to the two sets of JDM injectors I have: H23A and F23A. I just got a JDM H23A, and pulled the rail and injectors. I know now that the JDM fuel rails are much different than the USDM ones, and sit a little closer to the runners, hence the shorter injector length. I would sell you my JDM rail so you can run the Euro-R injectors, but the inlet is on the driver's side, so I'm not sure you could run it without a custom fuel inlet hose.
MRT
Selling on Ebay!
15.10 @ 90.42mph
Current fastest Laguna Seca Lap: 1:55.317
af_1132 is offline   Reply With Quote
Old 04-21-2019, 09:30 PM   #10
Jarrett
https://roskoracing.com/blogs/news/m...ntake-manifold
Old 04-23-2019, 03:24 PM   #11
HenRoc
Black Thunder
HenRoc seems to have made some friends! HenRoc seems to have made some friends!
Send a message via AIM to HenRoc
I'm trying to do some heavy handed research on that block as well, because if I do end up deciding on another H22, it's definitely the Euro R now that it's reasonably priced without the transmission.
My main issue that hasn't been really covered are:
- What basemap to use
- Which H22 injectors to use
- Which fuel rail to use (and I've used your MR thread as reference G. Wiff)
- And if you can still use C/C
Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
HenRoc is offline   Reply With Quote
Old 04-23-2019, 03:38 PM   #12
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
- Use an H22A4 map if you can find it, H22A1 if it's all you can find. Ideally you'll get a custom tune. There are also pre-made tunes that are designed for slightly higher lift cams and/or other ignition improvements, they would likely work nicely.
- If you have the Euro-R injectors, use those with the resistor box bypassed. If you don't have them, use any H22 injectors that you can find - although you'll need to trim your manifold as per Rosko's instructions. OBD1 H22A1 injectors would avoid messing with the resistor box, and you can mock-up using common F22 injectors for sizing.
- Ideally you will have the Euro-R rail, and it would match the Euro-R injectors as-is (though need fuel line extending), or if you want to run your CB7 fuel rail or other normal H22 injectors, you will need the spacer kit from Rosko.
- Cruise control works fine, just make sure you hook up the vacuum line.
Old 04-26-2019, 05:26 AM   #13
HCoupe
HCoupe is cool... so far.
Thanks Jarrett and cp[mike], that's exactly the right answers. The only thing I can add without googling the exact numbers (because I'm lazy and I'm 80% sure those are the numbers), is that ODB2 H22 injectors are 245 saturated whereas Euro R injectors are 270 saturated, and the OBD1 H22 injectors are 310 or 340 peak and hold.
The performance losses from using any other H22 injectors and not porting the injector holes are "small" (maybe 10HP-ish and a tenth to two tenths slower 1/4 mile times), so get the car dyno tuned after porting the holes for optimal fun.
The problem I did run into by using OBD1 injectors and not porting the holes, was when the temperature was above 90 and I was running the car for a prolong period of time (especially coming off the freeway) the car would die randomly, and then I'd have to give it gas to start it and keep the rpms up with the gas pedal or it would die again, I could ease off the gas until it idled, but that was annoying. After I ported the holes, I've never had that issue again.
HCoupe is offline   Reply With Quote
Old 10-28-2019, 02:35 PM   #14
G. Wiffington
I never even looked back at this thread.
I am now getting curious again about the Euro R injectors.
I am looking to put the euro r back to the oem injectors & the R fuel rail.
Since running the OBD1 H22 injectors with the F22 fuel rail & rosko accessories
I never had an issue & my car pulls pretty hard. Never had any dying issues
or anything like that.
I would like to get the R injectors, R rail & bypass the resistor box to see
if I get any more power out of this thing.
I do not know much about the flow rate or cc's produced but from datalogging
I have maxed out the OBD1 H22 injectors. I am wondering if it is due to the
spray pattern compared to the correct injectors I should be running.
Keep Pushing..
Old 10-29-2019, 12:09 AM   #15
Corweena
Corweena is cool... so far.
I'm no expert on injector flow myself, but Rosko also sells parts so you can use the RDX injectors as an upgrade. The 2 friends I know with Euro Rs both went that route.
Corweena is offline   Reply With Quote
Old 10-29-2019, 02:21 PM   #16
G. Wiffington
I did see that from Rosko.
Keep Pushing..
Old 11-16-2019, 10:07 PM   #17
CyborgGT
Your injector ports were opened up for the non-R spray pattern?
As for the RDX injectors, you'll want to ask Rosko if his special rail is needed. My setup came complete (R manifold + RDX + full Rosko treatment), so I can't speak on compatibility. The whole thing looks like it might be a bit complicated, depending on what parts you already have. I would think RDX injectors are much easier to come by, and have a higher potential, though.
https://roskoracing.com/blogs/news/e...ld-parts-guide
*ED. - https://honda-tech.com/forums/honda-...-size-3174343/
310cc Euro R, compared to the RDX rated at 410cc (@ 38 psi) and 550cc (@ 70 psi).
