You might have adjusted your hood latch too high. Try to bring it down some and see if there any rubber stoppers you can adjust on the radiator support or something.
LosiRacer2 : 1993 Accord EX
this came in the mail today, I needed these BAD too, esp. after wacking my balljoints w/ that pickle fork that obliterated the boots, which were torn already lol
member's ride thread
91 Accord SE 176k
So i finally got around to doing the boots, I had no choice for the tierod boots at autozone, so i had to go w/ red for those but everything fit fine and my car drivers a lot "tighter" now that there is grease in the balljoints and tierod ends. Before, the upper balljoints felt really gritty and a lot of friction was noticeable, now, the suspension seems to work much better and there aren't any noises coming from the front
^^^new upper boots by ES, they fit like a GLOVE, i even heard them snap in place....sweet
candy apple red ES tierod boot
Lower balljoint boot fixed!
the old shits, that gave me rattles and squeaks.Last edited by Losiracer2; 08-15-2017, 03:38 AM.
91 Accord SE 176k
So I found a ST Rear Sway Bar from a guy locally for only $40! BRAND NEW! and I installed it today. I can really feel the difference in the cornering like everyone says, it feels a lot tighter and nimble
^^58 pieces in total.....phew that was a lot of assembling, but wasn't bad.
^^comparison from my old Vigor to my new 21mm ST RSB.
16mm vs 21mm
^^^cardboard, mans best friend.
^^it even clears my exhaust perfectly fine.
^^polyurethane endlinks
tons O clearance
mmmmmm BEEFY!Last edited by Losiracer2; 08-15-2017, 03:39 AM.
91 Accord SE 176k
Originally posted by Chrisfrom1986Sweet swaybar. I need to start gathering things for my CB to handle as well as my next Supra.
91 Accord SE 176k
dude your car is beautful...and im loving all the new upgrades
New & Improved 93 Accord EX Coupe
what makes a man a man?
Originally posted by ric3rboi23disrespect females, acquire currency.
hey man, it's nice to hear you like the sway bar, i have a full set (ST 21mm for the rear and 27mm for the front) waiting to be put on this saturday, and i can't wait!MEMBER'S RIDE
i was driving along today and the check engine light came on.
i pulled over and looked under the hood.
the engine was still there...
...silly light!
Originally posted by blamethepunxhey man, it's nice to hear you like the sway bar, i have a full set (ST 21mm for the rear and 27mm for the front) waiting to be put on this saturday, and i can't wait!
91 Accord SE 176k
Originally posted by Juice21dude your car is beautful...and im loving all the new upgrades
91 Accord SE 176k
Originally posted by Losiracer2oh damn you went all out! yeah it was kinda fun installing the sway bar, well not TOO fun since I got dirty beyond belief rolling around on the ground lol, but just assembling it, was kinda interesting, the instructions SUCK BALLZ but I managed eventually.
ha ha, gettin dirty is what it's all about
i can't wait to get my sway bars on. if you felt a difference going from a vigor sway to the 21mm, i should feel a huge difference. the stock ex-r one is thin and flimsy
-seanMEMBER'S RIDE
...silly light!
So today, since I found a FRESH 92 EX sedan w/ 120K and a good steering wheel, ie: the vinyl wasn't coming unglued like it is in mine, I swapped that one in for my old nasty one. I learned a lot about my airbag too, lol...thank god it didn't deploy in the meantime.
airbag off
all the sensor doohicky's
I put the cruise control back on
the airbag itself
All mounted up, new JY steering wheel for $15.
don't forget to disable this switch on the bottom first, before removing the airbag.Last edited by Losiracer2; 08-15-2017, 03:40 AM.
91 Accord SE 176k
oh and here's pics from the valve adjustment I did about a month ago, I replaced the RockerArm O-rings too, that plagues most of the engines at this age.
Here's some pics I took when I did the replacement of the Rocker-arm O-rings:
old petrified O-rings that didn't seal for shit
new O-rings, much softer rubberLast edited by Losiracer2; 08-15-2017, 03:41 AM.
91 Accord SE 176k
