Old 01-08-2014, 09:50 AM   #1
CrunkRuffRyderz
CrunkRuffRyderz is cool... so far.
Am I cross threading my fuel line?
I have a 93 Accord and I just can't seem to smoothly thread in the hard fuel line to the new fuel filter. For starters the bracket has been loosened enough to make the 2 ends aligned, but once I go about 2 or 3 lines of thread in, it gets very stiff. I am positive that I have the hole and fuel line aligned, so could it just be portion of the line that screws in (male end) has gotten stiff over time? I really can't afford to cross thread this but everything from my perspective is telling me it shouldn't be. Any ideas?
I'm thinking of using pb blaster next but don't know how flammable it may be or if any seeps into the filter how damaging that may be to my engine. I'd hate to have a shop do it, especially if it's just a matter of cranking on that sucker, but then again if they break they buy.
CrunkRuffRyderz is offline   Reply With Quote
Old 01-08-2014, 11:35 AM   #2
FGR
FGR is cool... so far.
Send a message via Skype™ to FGR
you could try putting some wd 40 on you finger and put it on the treads it might just lube it up to where it will screw right on. (correct me if im wrong) let me know how it goes i have to do mine soon too
work in progress
http://www.cb7tuner.com/vbb/showthre...07#post3185107
FGR is offline   Reply With Quote
Old 01-08-2014, 05:08 PM   #3
fleetw00d
Pb blaster, WD40, a little oil, none of that should be a problem. Make sure the threads are clean. You could even go to the extent of getting a thread die to clean up the threads on the nut. If it goes relatively easily for those 2-3 threads, try manipulating the line to seat the flare at the bottom of the fitting so that it is not preventing the nut from going further.
90 LX 4dr 5 spd 373,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 253,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 170,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=205114
Old 01-12-2014, 12:21 AM   #4
CrunkRuffRyderz
UPDATE: The filter I had was an O'Reilly filter, and somehow the threads did not line up properly. There actually were metal shavings coming off of the threads on the filter. The hard fuel line was intact with zero damage. I bought a Honda branded filter and it went on smooth as silk. Lesson learned but hopefully can help someone out there who may be experiencing this issue with an aftermarket fuel filter. Thanks for the input everyone!
Old 01-12-2014, 05:43 PM   #5
FGR
no problem man!! i had a similar issue. my oil pressure light keep coming on randomly, i put a autozone one one it stopped for a week then started coming on and off at random. after testing the electrical i went to honda and got and oem one. havent seen the light since. sometimes oem is the way to go
work in progress
Old 01-12-2014, 10:50 PM   #6
steelbluesleepR
I shoot people
steelbluesleepR seems to have made some friends!
wait...what? your fuel line would have nothing to do with the oil light. Your engine (or your oil sensor) has some serious problems if you're getting oil lights.
Originally Posted by Stephen Fry
steelbluesleepR is offline   Reply With Quote
Old 01-13-2014, 11:32 AM   #7
fleetw00d
He was just providing another example of where an aftermarket part didn't work and OEM did.
1993 , cb7 , cross threading , fuel filter , help me
