Thread Tools Rating: Thread Rating: 27 votes, 5.00 average. Display Modes
Old 01-10-2005, 04:36 AM   #21
timmy0tool
Accord of the Month: April 2006
timmy0tool is cool... so far.
Send a message via AIM to timmy0tool
hectic702: you can replace the master cylinder but it's not necessary (read below why). the fluid gets to the rear via brake lines just like it would on the drums. the drums are mainly hydrolic. the cable is just for the e-brake.
HondaFan81: i bought the whole set at a local junkyard. yes i retained the stock smaller brake master cylinder, brake booster and proportioning valve and i am happy with the results. any car would benefit from any upgraded parts but my stock setup all worked fine for me. the proportioning valve could make the most difference due to a better braking bias between the front and rear wheels. typically people use the prop valves off the DA integra RS (non-ABS) which are stamped 40/40. they are bolt on, but i find the current accord one to be fine. the EX/SE booster is the same i believe. the EX/SE master cyl is only larger by a few mm. it's not worth the effort unless your current set is already failing (we do have 12+ year old cars).
i have great braking feel up to now (it's been a year and 2 months now). it is more positive and responsive compared to the drums. what more when you upgrade to stainless steel lines; i don't have them though. going 65mph, i can lock up my 17's with 215/45 tires on the freeway.
i got lucky with my parts. it was all in good condition and complete down to every brake line i needed. as for the calipers, they were in decent condition so i didn't touch them. my rotors were pretty decent as well so there was no need to resurface them. when you get a set, i recommend that you change the pads, resurface the rotors, and overhaul the calipers just in case. you never know what car or condition they came out of. i chose not to do any due to the satisfactory condition my set was in. i'm still using the pads that they originally came with from the junkyard!
1cor10:31
- 92 LX coupe
- 96 EX wagon (sold)
timmy0tool is offline   Reply With Quote
Old 04-08-2005, 02:54 PM   #22
krakakru21
krakakru21 is cool... so far.
my buddy is going to be giving me his discs off of his 92 accord(what a dumbass) and i am going to be giving him my drums. my question is when swapping them will it unbolt and bolt up with no problems or is there different lines i need to use. he will be getting my whole drum setup and i am getting the entire disc setup. my lines are going to his car and his lines are coming to mine. please let me know ASAP becuase i am going to be doing it shortly
www.rms-usa.com
krakakru21 is offline   Reply With Quote
Old 04-08-2005, 06:53 PM   #23
timmy0tool
dang that's a really good deal and yes your friend is a dumbass for doing this. anyway yes it will unbolt and bolt up with no problems at all. you just have to make sure you remove the correct parts. don't forget that you will need the emergency brake cables on top of the regular brake lines. just remove the whole suspension assembly.
from the donor car, remove the:
-upper arms from the chassis
-WHOLE lower crossmember (so you can use the rear sway bar too!)
-trailing arm from the chassis (near the jackpoints along the sideskirts)
-regular brake lines
-emergency brake lines
of course there are obvious things you have to remove in order to remove the parts i just listed (like the exhaust heatshield in order to remove the emergency brake cables).
just remember that you CANNOT transfer over the ABS sensors and lines so just leave those in the donor car. cutting them might trigger the ABS light in the instrument cluster of the donor car. good luck man!
1cor10:31
- 92 LX coupe
Old 05-06-2005, 11:32 AM   #24
RocSteadyNy
RocSteadyNy is cool... so far.
Send a message via AIM to RocSteadyNy Send a message via Yahoo to RocSteadyNy
why can't you change the abs sensors?
RocSteadyNy is offline   Reply With Quote
Old 06-07-2005, 10:00 AM   #25
f22-dohc
f22-dohc is cool... so far.
did mine last week!!!!
sick!!!!!
welcome to the DOHC-side..muuuahahahahahah
http://www.cb7tuner.com/vbb/showthread.php?t=1906
f22-dohc is offline   Reply With Quote
Old 06-07-2005, 10:10 AM   #26
phatdoughnut
phatdoughnut is very helpful phatdoughnut is very helpful phatdoughnut is very helpful
Send a message via AIM to phatdoughnut
I swapped mine over, and i also upgrade my front brakes to the Ludevtec 11.1in rotors and calipers. I need a new Master cylinder!
on to another important question. i took all mine of the doner car along time ago, so i cant remember where the mounting points are for the sway bar, any help?
*edit*
Nevermind i know why i cant do it, i dont have the stabilizer brackets that the bushing a C clamp thingy attach to the chassy. ***!
phatdoughnut is offline   Reply With Quote
Old 06-10-2005, 01:01 AM   #27
gutterslide
gutterslide is cool... so far.
Send a message via AIM to gutterslide
are rear disks rotor over hub?
gutterslide is offline   Reply With Quote
Old 06-10-2005, 03:41 AM   #28
timmy0tool
yes they are. i don't believe a hub-over-rotor exists out there.
1cor10:31
- 92 LX coupe
Old 06-12-2005, 11:33 AM   #29
According2Me
According2Me is cool... so far.
Send a message via Yahoo to According2Me
so when doing this conversion the origonal sway bar wont work... so youd have to use the rotor systems sway bar?
. . .93 Ex F2.0A Si. . .
WiredMotorSports
According2Me is offline   Reply With Quote
Old 06-14-2005, 04:14 AM   #30
bracersi
bracersi is cool... so far.
Send a message via AIM to bracersi
Dayum good write up. That is gonna be my next upgrade
my ride
bracersi is offline   Reply With Quote
Old 07-29-2005, 10:08 AM   #31
zipcreature
zipcreature is cool... so far.
Send a message via AIM to zipcreature
THere is a nice set of these in the junkyard. I told him $240, and he said "per side maybe!".
How much did you pay for the rear disks?
- Zipcreature
Awesome!
CB7. F22A. 5spd. CB7. Exedy. Chromoly. AEM. DCSports. Apexi. Progress Group. AGX. Suspension Techniques. Viberant. Goodridge. Facebook
zipcreature is offline   Reply With Quote
Old 07-29-2005, 04:23 PM   #32
zipcreature
bump.
- Zipcreature
Awesome!
Old 07-29-2005, 05:04 PM   #33
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
im selling my set to a friend for ~180...
i say dont spend anything over 250.
Old 08-03-2005, 06:27 PM   #34
timmy0tool
an OEM bar can work if you swap over the rear crossmember as well. the 92-93 EX/SE crossmembers have the holes for the sway bar brackets. all trailing arms have a hole for a sway bar be it a DX, LX, EX, or SE etc.
note:
90-91 EX has a rear sway but are still drum brakes.
all DX/LX never came with a rear sway standard.
all accords with rear discs have rear swaybars.
1cor10:31
- 92 LX coupe
Old 09-25-2005, 01:39 AM   #35
Ronald_Type-R
Accord of the Month: March 2007
Ronald_Type-R is cool... so far.
BUMP for an old thread!! hehe I have a question for y'all...I'm getting a set of rear discs...Comes with upper arms, brake lines, etc etc EXCEPT for trailing arms...My friend told me that the discs will bolt up fine with the trailing arms that I have now (w/ drums) He said that he's done some research, and the part number for trailing arms w/ drums are the same with the ones w/ discs...
Jus curious if anyone can plz confirm me on this matter...I jus want to make sure that these babies will bolt up fine on my trailing arms, so that way I won't have to look for trailing arms for discs..hehehe can anyone plz help me on this?? Thx in advance! Oh and pic below
Ronald
|~~~~~~~~~~~~- Project CL1 Euro-R continues -~~~~~~~~~~~~~~|
Ronald_Type-R is offline   Reply With Quote
Old 09-25-2005, 01:47 AM   #36
micksf22accord
micksf22accord is cool... so far.
Send a message via AIM to micksf22accord Send a message via MSN to micksf22accord Send a message via Yahoo to micksf22accord
I have the whole thing for sale
$210
Off a 92 ex coupe
Dynamic racing
Look out for 4 point cb7 strut bars for dohc!!!
Originally Posted by deevergote
bleh... i just put like 5 ounces of vodka in a 12 oz cup of mango iced tea...
micksf22accord is offline   Reply With Quote
Old 09-25-2005, 02:25 AM   #37
Ronald_Type-R
Thx bro, but I actually already got those things that is on the pic...It's jus at my friend's house, and I haven't got time to pick 'em up yet...That's why I'm asking you guys to check if I can use my stock trailing arms with the discs...
Thx for the offer tho man
Ronald
Old 09-25-2005, 02:42 AM   #38
micksf22accord
Ronald
lol i know your buying that one
Im trying to sell it to someone reading this thread ROFL
please buy it
brand new pads!!!
new rotors 3 months ago
please buy
It needs a home
Dynamic racing
Old 09-25-2005, 04:55 PM   #39
uslspct
uslspct is cool... so far.
Send a message via AIM to uslspct
Ronald
Yeah, it will be fine. Just more of a hassle to bolt them up.
Metal Metal and more Metal!!!
How much does your wheel/tire combo weigh? Post here!
-=Suicide Crew Member #1 (only member so far)=-
MY RIDE
"I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
uslspct is offline   Reply With Quote
Old 09-26-2005, 10:20 AM   #40
timmy0tool
yeah ronald the trailing arms are the same but it will be a bit harder to do, but not impossible. the ebrake cables on the drums go through the trailing arms unlike the cables on the discs which only outline the trailing arms. other than that and some more bolting and unbolting, you should be fine!
good luck with the install and post pics when done!
btw, it looks like the set you have in the pic is missing the screws that holds the rotors to the hub. make sure to not forget that .
1cor10:31
- 92 LX coupe
brake , swap
