Thread Tools Rating: Thread Rating: 50 votes, 4.70 average. Display Modes
Old 02-23-2015, 09:06 PM   #1481
Raf99
Old 02-25-2015, 04:45 PM   #1482
Raf99
Got some new rear hubs and axles. Glad I got the axles as the old ones are super loose compared to the new ones...
Old 03-01-2015, 02:59 PM   #1483
choppacity
choppacity seems to have made some friends! choppacity seems to have made some friends!
Congrats on AOM, Keep up the good work!
Originally Posted by Quashish View Post
Holy crap thats a clean F series. jellish mang.
Quashish dictionary
Jellish: (adjective) Jel-%i'sh+#
To envy something to point of almost blowing a load involuntarily.
choppacity is offline   Reply With Quote
Old 03-02-2015, 08:22 AM   #1484
Raf99
Thank you & I appreciate you stopping by!
Old 03-02-2015, 07:30 PM   #1485
Raf99
Big thanks to DanCan here!
You are looking at:
- New axles
- New upper poly control arm bushings
- New poly stabilizer bushings
- New lower control arms
- New inner/outer tie rods
- New inner axle seal
- EBC drilled/slotted rotors
- EBC brake pads
- Braided brake lines
- ESP traction bar
- SPC +/-3.0 camber kit
- Tein Super Street coilovers
New hardware, undercoated the area before all parts went in..........and we are finally done the front end!
Only thing I am concerned with is that i heard somewhere its best to torque the lower control arm inner bolt after the car is on the ground and not before. Same goes with the upper control arm bushing bolts.
Old 03-02-2015, 08:42 PM   #1486
GhostAccord
Yes sir....No need to put the wheel on though. Leave those bolts a bit loose and slowly drop the knuckle down onto a jack stand/4x4/log of wood. Once the suspension bottoms out from the weight of the vehicle, torque those bots to spec.
looking good!
MR Thread
GhostAccord 2.4L Blog
by Chappy, on Flickr
Old 03-02-2015, 09:06 PM   #1487
Tishock
Tishock is someone to admire Tishock is someone to admire Tishock is someone to admire
Hey Raf99, You have the shock forks on the wrong sides of the car. You need to swap them out and the fork bolt should be facing towards the engine.
Tishock is offline   Reply With Quote
Old 03-02-2015, 09:57 PM   #1488
illinois_erik
i did that on the other car and drove for a while like that, then realized what i did when i had discrepancies assembling the swap car lol
Old 03-02-2015, 10:27 PM   #1489
XCRN
XCRN is cool... so far.
Isn't there a big "L" and "R" on the forks?
Be unique, like every other person.
XCRN is offline   Reply With Quote
Old 03-02-2015, 10:56 PM   #1490
Tishock
Yeah, I did this once. I didn't notice it until I started putting the wheels on. And it as was at the end of a very long day, so I was not pleased.
Old 03-03-2015, 06:07 AM   #1491
illinois_erik
that sucks man, shit happens though, i made sure not to rush this last rebuild and have had maybe 2 minor overlooks need corrected after a few hundred shakedown miles
yeah but mine were hidden in road grime..
Old 03-03-2015, 01:46 PM   #1492
Raf99
looking good!
thanks....
ahhh yes. I have the shock forks on the wrong side. doh. Thanks for pointing that out. Should be able to pop the shocks out and swap the forks and put them back in
Old 03-03-2015, 03:40 PM   #1493
DanCan
DanCan is cool... so far.
You are looking at:
- New axles
- EBC brake pads
- ESP traction bar
No Problem man. Glad it got there and glad you got the front-end all back together.
As for the bushings...I never did with mine. To be honest, I totally forgot about it. Its different than an OEM bushing as they are all one piece, the sleeve is molded in to the rubber and on the LCA the outer ring is pressed in. It would tear and rip if you tightened it down and then lowered the car. The poly is separate pieces, and can still move around the arm and sleeve.
Can`t be too safe tho....I have no issues with mine. LOTS of grease so no squeaky squeaky....lol.
Project:Black Skittle
AOM->April 2014
MRT->http://www.cb7tuner.com/vbb/showthread.php?t=199779
DanCan is offline   Reply With Quote
Old 03-03-2015, 03:49 PM   #1494
Raf99
Hey everyone. If you had to choose between a M2B4 or a T2W4 which would you choose?
Old 03-03-2015, 05:38 PM   #1495
8ball
8ball seems to have made some friends! 8ball seems to have made some friends!
Question
Big thanks to...
DarkCloud, TypeG, rocketman_471, cb7rush, Theos92VR4(x2), almostJDM, , NightmareCB7, xkjnboix, almostJDM, H23CB7, tommi, 1990[H]accordex, treyd82, dannyd, bmxicansd, STREET-SPEC, 93a-lude, lindiz, DanCan and many others for the help
410WHP @ 17PSI
Engine & Components
Exterior
Tein Super Streets
Front SPC front camber kit
Rear Ingals camber kit
Ractive front upper strut bar
Ractive rear upper strut bar
Ractive rear lower tie bar
Clear bumper signal lights
JDM side marker lights
JDM intersection lights, relays and harness
JDM yellow fog light bulbs
Red/Clear Sedan tail lights
- CB7 JDM one piece black housed headlights
- Yellow high beam shroud
- JDM yellow high beam bulb
- DS2 Mini projectors w/ electronic cut-off shield (theretrofitsource.com)
- Gatling Gun mini shrouds (theretrofitsource.com)
- Phillips 85122 bulbs (theretrofitsource.com)
- 100mm halo rings high beams (theretrofitsource.com)
- 90mm halo rings low beam (theretrofitsource.com)
- Wiring splitters (theretrofitsource.com)
- HID ballast (theretrofitsource.com)
Headlight shields/covers
Earl's braided steel brake lines
Rear disc swap
17" RTX Poisen Series rims
EBC Front drilled and slotted rotors and pads
EBC Rear drilled and slotted rotors and pads
80% tint on rear windows and back window
4 Window wind visors
Shaved antenna
Shaved logos
91 DIY front grill
Rear camera DIY into taillight
95 JDM Honda Accord front lip‏
95 Accord EXR rear lip
Interior
97 Prelude front seats
Dyed black floor mats
Dyed black mat of rear seat
DIY black interior pieces
Complete DIY trunk redo with black fabric
ICE
Alpine IVA-D310 In-dash 7" DVD screen
Alpine MRV-1507 class D amp
2 x 400W Clarion 10" subs
Alpine Flex5 MRP-F365 amp
Qlogic corner enclosures w/
Alpine crossovers w/
Alpine 300W 6-1/2" 2-Way component speakers w/ tweeters
Pioneer 180W 6 1/2" rear speakers
Pioneer 140W 5 1/4" front speakers
Alpine I-Pod interface adapter
If you read this far congrats! This list is getting way too long
Future Plans
Rear upper sun visor (have)
Carbon fiber hood (do not have..)
************************From this point below are pics when I started my MRT. As the pages go on, so do the updates and pics
Some of the coolest things beside the HP are the headlights and Oem interior Two tone integration.
8ball is offline   Reply With Quote
Old 03-03-2015, 08:13 PM   #1496
Raf99
Thanks man!! Means a lot that you see the detail!
Unfortunately the interior is going mostly black. Black rug, arm rests, doors, back sil. But you do have a point.......
I may want to start thinking of a two tone, style, or design. Don't wanna Johnnie cash theme going on fully....
Old 03-03-2015, 08:17 PM   #1497
Raf99
OK ya... haha. Lesson learned on my behaf. That green move took me 2 hours to fix. Had to take the whole knuckle out as the teins are tall, the traction bar thick enough the dam shock wouldnt come out.
Old 03-03-2015, 09:25 PM   #1498
SPLCB7
SPLCB7 is cool... so far.
Send a message via Yahoo to SPLCB7
What did u use to die your floor mats I need to die mine...
My 90 coupe Mr thread....
SPLCB7 is offline   Reply With Quote
Old 03-04-2015, 08:26 AM   #1499
Raf99
I used spray can fabric dye. Worked great, but the drivers side mat is starting to fade since it sees a lot of use. You can pick this up at any auto store, etc.
Old 03-04-2015, 09:34 AM   #1500
DanCan
LMAO...We are definitly thinking on the same level...This is what I used.
AOM->April 2014
