Every couple of days I have to put brake fluid on my car, why is that? Every since I found out that I have head gasket issues, I have notice that I'm losing brake fluid as well. Please help me. Do I need to replace my master cylinder now ass well since in already putting a motor on my car?
Brake fluid Issues
You have a leak somewhere; find it and fix it. If you're having to add every couple days, a leak should be fairly evident. Check not only around the master cylinder, but at all four wheels (caliper and/or wheel cylinders) and brake lines. Also check inside the firewall where the master cylinder push rod comes through to the brake pedal, it can be leaking there and loading your carpet with brake fluid.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
