Power steering return line leak
    Hi all,
    Have a leak in my power steering return line at this rusted up metal clamp. Is there anything wrong with sawing it off and just zip tying new rubber hose on? Any reason why there's metal there when the rest of it is regular hose?
    https://imgur.com/a/0ebqS
    Thanks!
    Don't use a zip tie. If you can get that clamp off, use a screw type hose clamp. The type that is on there tends to dig into the hose and effectively relax the clamp on the tube. The wider band clamp will spread the clamping load more and not dig into the hose so much.
      Thanks. So you're saying maybe I don't even need to replace the metal tubing?
        Is it actually the tube leaking, or the hose at the joint?
