the f22b vtec is really no different than the regular f22a until the vtec kicks in... i dont think its worth the extra $ a f22b nonvtec would be a much better investment
f22a4 to f22b1 vtec swap
well u basically have 2 options: get a pO6 chipped; them use crome/uberdata to intialize vtec, wire it up
2nd option is get the original ecu(pOA), but dont know if this would be beneficial as far as performance"You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
If you have the b1 vtec a chipped p28 will work. If not you can run the stock POA i think thats the one but its not really chippable. More common is the p28 for those vtec motors.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
Originally posted by NYKnick1015the f22b vtec is really no different than the regular f22a until the vtec kicks in... i dont think its worth the extra $ a f22b nonvtec would be a much better investmentfuck the bitches that stole my car jan/1/2006@7am from montesano wa updated: The Warrens from Malone Wa were found guilty for possesion of stolen property in the 1st*and were ordered to pay $2489.69 in restitution, only cause the shell was not found
R.I.P.
Vouches from: Snailin91, Caution, 2G6, Jdmf23accord, Boosted_StinkyNuts
Originally posted by NAiL05If you have the b1 vtec a chipped p28 will work. If not you can run the stock POA i think thats the one but its not really chippable. More common is the p28 for those vtec motors.
Ive I wanted to chip the ecu myself what are the tools I would need?
check the forum they are for sale here you will not be spoon feedfuck the bitches that stole my car jan/1/2006@7am from montesano wa updated: The Warrens from Malone Wa were found guilty for possesion of stolen property in the 1st*and were ordered to pay $2489.69 in restitution, only cause the shell was not found
R.I.P.
LOL!
You really should learn to spell before attacking people.
Easiest ECU solution: Find an OBD-I F22B1 ECU from a1994-1995 Accord EX. Add the VTEC wire and be done.
LOL! At SOHC VTEC breaking the tires loose when it kicks in. Unless you have some heavy mods, you have about 5 more HP than an F22A6.
How do I know? I have experience with NUMEROUS F22B1s. Not real impressed honestly. The fundamental design is geared more towards economy.
You can buy F22B JDM DOHC non VTEC engines all day long for $700 shipped. That might be a little more than an F22B1, but it is a straight bolt in engine, has about 15 more HP than the F22B1 stock for stock, pulls higher and has equal torque.
Not to mention that both the F22A and the JDM F22B have more potential because they have more aftermarket parts readily available.
With a few bolt on stock Honda parts, he can have his F22A1/A4/A6 making just as much power as an F22B1, so why bother with the swap?
Originally posted by NaturalRootsok so do you know where I can buy a p28 chipped, poa, or p28?
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
Originally posted by NaturalRootsalso I wanted to know if my old alternator, starter will work with the f22b
The starters are interchangeable on like transmissions. So if you have a 5 speed and are keeping a 5 speed, then yes, it should work without any issues.
The alternators are the same, although depending on what wiring you use, the plugs at the alternator end MIGHT be different.
Originally posted by pig penmy suggestion is dont put the B1 in it. The vtec sucks on these motors and they are hella slow. My buddy dale has one and i can kick the shit out of it with my auto. They are kinda gutless motors. I would stay with the F22a4, rebuild it, and put some bolt ons on it.
Originally posted by owequititThe starters are interchangeable on like transmissions. So if you have a 5 speed and are keeping a 5 speed, then yes, it should work without any issues.
thanks appreciate it I will be taking some pics to show the progress.
Originally posted by Gen4Accludeyes it will run the car but will cut out at 4600rpm with out the vtec hooked up do you have a tach with a shiftlight like a auto meter if so hookit to the wire with the tracer lines on it going to the actual light from the wiring harness
Is this the kind of tach you were talking about:
No how do you go about hooking up the wiring harness to shift light?
