Lest we not forget the 96spec ITR wheels.
Official CB7 Compatible Parts Thread
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
Originally posted by Tippey764 View PostI tried to fit an h23 throttle body to an a6 plenum at the junkyard and it did not work.Last edited by SOHC-FTW; 09-15-2011, 04:17 PM.
02 Crv
evo pistons really work? do they take any modifications for them to fit?
also:
82-86 Toyota Celica Supra Wheels fit. barely clear the caliper but they cam in a 14x10 wide option on the P-Type along with 14x8 and 14x6 so theres a great candidate for some track wheels to put slicks on
The L Type are narrower 14x6 wheels around but theyre more rare
They rise their wooden pints and they yoik and sing
And they fight and dance 'till the morning
Dont forget my MRT for my 1992 Honda Accord LX
Originally posted by deevergoteEverything in Japan is made with carbon fiber and used panties.
This thread is helpful so Im bringing it back
94-97 accord rear seats bolt right in the bottom cushon is a little short on the sides.
92-96 prelude main relay, shifter plate, shifter cables, clutch pedal/master cylinder.
94-97 accord steering column is a direct fit for a obd2 steering wheel swap.
92-95 civic corner light sockets fit right in the cb bumper lights for a running light modLast edited by DarkHusk11; 02-06-2012, 09:28 AM.
1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
Originally posted by keepinitcleanI give it 2 weeks before you sell it.
Bumping this.
94-96 Prelude & Acura Vigor leather handbrake boots fit over the stock handbrake handle.
DA Integra shift boot works (with matching or similar shift knob). Need to take the DA boot off it's retaining ring and put it on the CB's.
With the Prelude shifter plate mentioned above, it does fit in the Accord, but takes a little wiggling to get it in. You do not have to use the Prelude shifter plate. You can simply remove the Prelude shifter and fit it into the Accord plate, as long as you cut down the numbs for the shift throw limiters on the shifter. Otherwise the Prelude shifter will have almost no room to move back and forth in the CB shifter plate.Last edited by crazymikey; 02-29-2012, 02:13 AM.
Originally posted by J3wman View Postevo pistons really work? do they take any modifications for them to fit?
also:
Prelude VTEC knuckles and rotors (same ass CC5 and CB9), and calipers all the same part number.
BB6 Knuckles as well (96-01 Prelude)The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
92-95 Prelude front & rear seatbelts fit. edit: The rear seatbelts from the Lude fit, but they will not work, due to the tensioner locking due to the mounting angle being different from the Prelude, so basically, you can't use the rear belts. (Atleast they fit from a Prelude into my 90 coupe with manual seatbelts). Rear buckles may have issues as the strap is short. However the rear reels completely bolt in. For the fronts, the 10mm bolt hole is higher up, so just drill a new hole. The bottom hole lines up.
92-95 Prelude REAR seats fit...kind of. With LOTS of modification.
will post pic's soon...
1995 acura legend auto shift knob will fit, BUT the middle piece of the auto shiftier will always be engaged or pressed down, may try to find a way to fix this...
1995 acura legend heated seat switches fit into our center consoles, could be used for heated seats or anything...
