Weird Problem.............
    well i was on my way to school today, going bout 75ish on the highway and all of asuden the car just starts decelarating so i stop on the shoulder and figured it shut off on its own
    has anybody had a similar problem?
    thanks for any info
    -XS
    Did it turn back on or just shut off and stay off? Did the lights and everything cut out? Details plz...
      umm hows ur gas situation?
        wrichards2005: it shut off but lights were still on afterwards, after i pulled over it turned back on after 1 try.
        93accordexcoupe: had 1/2 tank left
        erikm: well i think if felt like a stall since it happened all of a suden (the car is AT), usually in the mornings its starts up nice unless its cold, then it takes a few seconds(when its cold).
        sorry still pretty new, whats CEL codes? and where do i look for them?
          I had a similar problem. Later, it started stalling on takeoff and in the middle of driving. It was as erik said, ignitor. BTW if it happens to be that and you take it to the mechanic, make sure they follow all the steps in diagnosing the problem. Even the part where it says if there is no code, after replacing everything else and the problem still exists, change the ignitor out. It took my mechanic a little while to figure out that was it and finally read that last part and fixed it right away. Good luck man.
            thanks for the info everyone. if the problem continues ill probably just take it to the dealer since i dont trust/ or have any shops around besides pepboys that i know of
