Go Back   CB7Tuner Forums > Site Features > DIYs > Exterior DIYs
Old 03-31-2014, 10:14 AM   #1
High5er
CB7tuner Member
High5er may have said something they shouldn't have...
EXT: HoA Badge Install
Sup guys,
I decided to install some HoA C-Pillar badges that I got from Trevor. I'm really OCD about where it goes so I started researching OEM placement. I looked around and found some other sources but I wanted to consolidate the information into one thread. I also wanted to include how I removed the old adhesive since it seemed like a common question. Here goes.
Stuff needed:
-3M tape
-Razor Blade
-Isopropyl Alcohol
-Napkins
-Expo Marker
-Straight Edge
-Leveling Tool
Alrighty, so I started off by buying the most potent rubbing alcohol I could pick up.
Took the napkin, folded it over twice, and lightly soaked it with rubbing alcohol.
I then took the badge and began to rub the backside into the napkin. I did it
until the adhesive looked comletely saturated.
Once the glue was nice and moist, I took a small razor and proceded scrape it off. (comes off really easily when wet)
You should be able to get almost all of the glue off in one pass. If it doesn't come off completely, rub the glue into the napkin again and keep on scraping.
*BE CAREFUL DON'T SCRATCH THE BADGE WITH THE RAZOR*
I was able to get all of it off with 2 passes. Super easy. If you're OCD like me and you need every last spec of old glue cleaned off, you can take the soaked napkin and spot clean the remaining sticky parts(rubs off easy).
BEFORE/AFTER
Got every last spec off
Now that I had a clean badge to work with, I was able to start to put the 3M on. The stuff I used comes in a roll and is 10 bucks at autozone.
Used the same razor, cut some pieces, and stuck them on. I tried to cover as much area as possible.
Alrighty, badge clean, new tape on, now we're ready to install the badge. This is where I did the most homework. I found another thread that had this picture. It was perfect.
The only speedbump I ran into, was that the measurements were in millimeters. Most of us are Americans and the closest thing we have to the Metric System is my tape measure in centimeters(maybe im just speaking for myself, lol).
For you math n00bs, take the measurement in millimeters, divide by 10, and you've got centimeters. (Psssst! Move the decimal over once to the left.) Magic.
I also found it kinda difficult to start taking measurements for best placement. What I did, was start with the vertical measurement. I made a small mark and then I measured and marked the horizontal length. I used a dry-erase marker because it wipes right off obviously.
It looked kinda off at first. It wasn't. I just took my straight edge and extended my markings. At this time, make sure your lines are level using a tool(I used my iPhone). You're going to want to have these perfect as you are going to use them as reference points for mounting.
*Quick tip: Make sure you line up the marking with the VERY EDGE of the badge*
After that, slap your badge on, stand back, and enjoy your work! Not for too long though, you still have to do the other side
Thanks for reading! Please let me know if I missed something! I hope this helps.
Gabe
__________________
Wrecked, Revived, and still Rollin'
Check out my MRT!
Quote:
Originally Posted by deevergote View Post
The most unique "modification" these days is a full restoration. Take a 20+ year old Honda and make it look brand new... and it'll be more impressive than the guy with the stock-block turbo and plastidipped steelies.
High5er is offline   Reply With Quote
Old 03-31-2014, 12:13 PM   #2
new_beginnings
Parts Masta
new_beginnings seems to have made some friends!
Send a message via Yahoo to new_beginnings
Those are really nice.
Awesome-ness to attention to detail from start to proper measuring/placement, to end result.
__________________
RETIRED...
new_beginnings is offline   Reply With Quote
Old 03-31-2014, 12:44 PM   #3
High5er
CB7tuner Member
Thank you sah!
I told you Im really OCD didn't I? Lol
I was really hoping I didn't mess up the placement. haha
__________________
Check out my MRT!
Old 03-31-2014, 03:45 PM   #4
oni_cb7
CB7tuner Member
oni_cb7 is cool... so far.
Clean write up. I wish this was up when I was installing mine 4 years back. I wasted so much time, no one had a diagram about where it should go. My best bet was just to compare it to photos and get it even on both sides of the car.
Great job!!!
oni_cb7 is offline   Reply With Quote
Old 03-31-2014, 03:54 PM   #5
High5er
CB7tuner Member
Quote:
Great job!!!
Ahh thanks man! It's good to know this thing was well translated!
Sometimes my wording gets all messed up when I type lol
But yeah thats why I made it. Didn't really see one solid write-up
__________________
Check out my MRT!
Old 04-01-2014, 01:36 AM   #6
SilverShadow
CB7tuner Member
SilverShadow is cool... so far.
Send a message via AIM to SilverShadow Send a message via Yahoo to SilverShadow
Great write up! So good I copied and pasted it in my bookmarks for when you know someone will ask about it again! I also am thinking of getting the badges but right now they are a bit too expensive at almost $50. Not a priority...and when it is, I know where to look to put them on correctly!
__________________
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
SilverShadow is offline   Reply With Quote
Old 04-01-2014, 08:28 AM   #7
High5er
CB7tuner Member
Quote:
Thanks man! Glad I could help!
__________________
Check out my MRT!
Old 04-18-2014, 05:14 AM   #8
SilverShadow
CB7tuner Member
Got some!!!! Thank you...Thank you Thank you!!! to the member who hooked me up!
You know I'll use this perfect DIY! Oni CB7, you'll see the results when I come to your 805/818 meet.
Here are some badges I have sanded and the HOA badges I just got today!
__________________
Old 04-18-2014, 12:11 PM   #9
High5er
CB7tuner Member
Nice! You should post up some pics of the finished product
__________________
Check out my MRT!
Old 04-18-2014, 02:50 PM   #10
SilverShadow
CB7tuner Member
Quote:
I will. I'm into bling on our cars, but it has to be genuine not aftermarket. I had 2 Aerodeck badges and one Accord Coupe..
I put one areo deck on wagon and put the others in a plastic bag in glove box..That wagon got stolen ..with them too.
Thinking of making 3 holes in the plastic door stills and putting the Accord carpet badges there like they have on metal ones. One of the 'H' will go on the Coupe. The other if someone wants it for $10-15.
__________________
Old 04-18-2014, 08:47 PM   #11
Raf99
Gold Member
Raf99 is very helpful Raf99 is very helpful
Nice attention to detail!
Old 04-21-2014, 08:46 AM   #12
High5er
CB7tuner Member
You know, ever since I saw the 92-93 grill emblem in the steering wheel, I've been dying to try it. It looked like it fit so well! I really like the badges in the sills though. I'm gonna try and retrofit the illuminated ones somehow from the newer models. Just gotta pick some up at payday! along with some other goodies haha
__________________
Check out my MRT!
Old 10-29-2014, 07:44 AM   #13
Frijoles
CB7tuner Member
Frijoles is cool... so far.
Where do you BUY these emblems? These and the other classic Honda emblems. I see all kinds of people on here with them, but I can't find them anywhere.
Frijoles is offline   Reply With Quote
Old 04-16-2016, 01:22 AM   #14
honda4674
CB7tuner Member
honda4674 is cool... so far.
Send a message via AIM to honda4674
Very nice write up. Thank you High5er.
__________________
1990 CB7 *RIP*
Current-91 EX and 92 EX
honda4674 is offline   Reply With Quote
