Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 07-30-2015, 11:40 AM   #121
LadyG
Golden
LadyG has a HUGE cock! LadyG has a HUGE cock! LadyG has a HUGE cock! LadyG has a HUGE cock! LadyG has a HUGE cock!
From the bowels of this section:
Bump!!
LadyG is offline   Reply With Quote
Old 07-30-2015, 11:07 PM   #122
PhatAccord
PhatAccord is cool... so far.
Send a message via AIM to PhatAccord
Bump!!
Hey LadyG, nice write up.
I had a few questions...
Based on your pictures; your accord is a manual transmission right? (Because it uses a half shaft)
Do you happen to remember if your new dr's axle inner joint had full splines or half?
I bought some lifetime axles from autozone and didnt have an issue replacing the passenger side. But on the dr's side, the axle I removed had a full splined inner joint. The new autozone axle inner joint was only half splined. Because of this, it would not fully seat inside the halfshaft. It would stop when the splines ended.
I double checked the parts along with autozone and their system said it was the correct part number.
Whats also odd is that according to autozone; the drivers axle and the passengers axle uses the same part number
PhatAccord is online now   Reply With Quote
Old 08-02-2015, 01:15 PM   #123
LadyG
Golden
Did some googling- found this.
Old 01-14-2016, 08:17 AM   #124
GeneralCodyLee
GeneralCodyLee is cool... so far.
Send a message via AIM to GeneralCodyLee Send a message via MSN to GeneralCodyLee
Thanks for the write-up!
im trying to conjure my tools i have scattered from all the moves i've endured..
Wish me luck!
Progress thread on my '93 CB7
GeneralCodyLee is offline   Reply With Quote
