Hello members. Got an issue with the RPM's dropping down to the first line above 0 on the tach. I believe its 200 or so RPM
1991 Accord LX
F22A1
5 speed
222K miles (daily driven)
It happens when I'm coming up to a stop or backing up to turn around. Have noticed it does it no matter if the engine is cold or warmed up. Coming up to a stop, down shift a gear or just coast with the clutch pushed in. Come to a stop and the RPM's drop to the last line on the tach. Stay there for a second or so then jump back up to 6-700 (average idle) while waiting to go again.
Today was the first time that when I backed up to park in my driveway, I stopped to go forward and my car died. Very first time it has done that. Usually just stays low in RPM's and then goes back up. But this time it dies/stalled. Started right back up again and idled fine.
What could be causing this? Throttle body need to be cleaned? Clogged fuel fuel filter? IAC or EGR need to be cleaned?
1991 Accord LX
F22A1
5 speed
