#1 |
Newcomer
power windows and door locks
Need help wiring up five pin relays for power windows and door locks. Need to know what color wires go where. Any help will be much appreciated. Thanks.
#2 |
Contributing Member
If you're going to attempt a project like this, I strongly urge you to get a factory service manual. That will have the colors and locations of any wire you need.
__________________
. If you see any threads or posts of mine whose picture links are broken (there are a lot), please send me a link to the thread. I will gladly fix them. I don't see it as a fruitless burden. This site has helped give me quite a bit of my drive and passion for cars, and fixing my picture links is the least I can do to give back. . |
#3 |
Newcomer
I do have a repair manual diagram. Just need to know how to wire up relays.
Thanks for your help. |
#4 |
CB7tuner Member
You need to know what pins on your relay do what, and compare that to the wiring diagram for your window switches. Are you putting in a really powerful stereo? Otherwise I think the stock alternator puts out enough juice that running them under any circumstances shouldn't ever be a problem.
To the veterans here, am I off base? |
#5 |
Gold Member
If it's a OEM relay it will show you in the manual how to wire it. If it's after market look up the schematic of the part #. No-one here is going to magically know how to hook up a random relay.
Tags |
power locks , power windows , relays |
Thread Tools | |
Display Modes | Rate This Thread |
