Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Image Gallery
Old 01-17-2019, 10:13 PM   #1
mAd mOrdigan
CB7tuner Member
mAd mOrdigan is cool... so far.
93 LX Sedan
I figured I’d document my build here. Needed a 4dr to haul my baby boy were expecting this month so I ended up gettin a 93 LX sedan!
Here is when I picked it up...
And immediately picked up a set of these...
They’re installed now but I gotta fix a broken wheel stud that the previous person either overtorqued or crossthreaded. Updated pics shortly after!
mAd mOrdigan is offline   Reply With Quote
Old 01-18-2019, 03:05 PM   #2
fleetw00d
Contributing Member
Great start! Looks rust free; that's half the battle for a lot of us. Need some wheels to dress it up a little.
__________________
90 LX 4dr 5 spd 385,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 191,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 01-18-2019, 11:37 PM   #3
mAd mOrdigan
CB7tuner Member
thanks man, as far as i can tell, it has some surface rust here and there but no cancer. It has a bit of a dent on the other side quarter panel otherwise its in great shape. Heres a picture of it lowered a bit.
I got some new wheels as well but now I have yet another wheel stud acting up. I can't even get the lug nut off to put these on!
Old 01-19-2019, 09:51 AM   #4
fleetw00d
Contributing Member
Those will make a big difference, what size wheel and tire? Is the nut cross threaded, or just rusted on? Soak it several times with penetrating oil. You might try tightening it a little first to break it loose, then try removing it.
Old 01-19-2019, 04:12 PM   #5
mAd mOrdigan
CB7tuner Member
Quote:
They’re 16x8 the tires are 205/45 but after it was all said and done, I wish I had gotten a bigger tire, I just wasn’t sure how it would with with a 20 offset. I was trying to avoid going lower on my suspension but I may just have to.
The nut I think is cross threaded and the stud splines stripped as it keeps turning but not coming off
Old 01-19-2019, 06:48 PM   #6
fleetw00d
Contributing Member
Is that stud on the front or rear?
Old 01-20-2019, 01:05 AM   #7
mAd mOrdigan
CB7tuner Member
Rear, the one I recently replaced was the front. I Couldn’t believe how easy it was. Lucky there’s space behind that rotor once you take the caliper off.
Old 01-20-2019, 05:11 AM   #8
Raf99
Gold Member
Ya, looks will be night and day with those wheels...
Old 01-20-2019, 10:56 AM   #9
fleetw00d
Contributing Member
Quote:
Rear should be easier. Although if the serrated hole is stripped, you might want to find another hub. Might be worth trying a little steel putty on the base of the stud; I repaired a hole in the oil pan of my 1999 Ford E350 a year or so ago, still holding (I have a spare pan if need be, but the engine has to be lifted to replace it).
Old 01-20-2019, 03:59 PM   #10
mAd mOrdigan
CB7tuner Member
I have it at the mechanic since I was gona have them charge the AC anyways. He said it may need a hub. Crossing fingers
Old 02-10-2019, 03:47 AM   #11
wanted18
Newcomer
wanted18 is cool... so far.
hi
post to follow
wanted18 is offline   Reply With Quote
Old 02-10-2019, 05:17 PM   #12
mAd mOrdigan
CB7tuner Member
guess I never came back to post an update. Here it is with the wheels on. Next item on the to do list is convert the AC refrigerant over to r134. All the r13 leaked out and i discovered a giant hole on the low pressure side hose that leads into the cabin.
Old 02-10-2019, 05:38 PM   #13
Raf99
Gold Member
Looks great man!
Old 02-10-2019, 08:45 PM   #14
Grumpys93
Contributing Member
Those wheels complement the car so well Nice grab!
__________________
~Nick~
Old 02-10-2019, 09:42 PM   #15
fleetw00d
Contributing Member
Told ya! Looks good!
Old 02-11-2019, 03:51 PM   #16
mAd mOrdigan
CB7tuner Member
Lol you called it. Just needed to see all your cars as inspiration before diving in
Old 02-13-2019, 11:20 PM   #17
wavepraiser
Newcomer
wavepraiser is cool... so far.
What brand are the shocks?
wavepraiser is offline   Reply With Quote
