I just got a 1991 honda accord ex coupe thats auto but I have a 93 accord lx, I was wondering if its possible that I can swap my engine, tranny and 5 speed into the 91 accord ?
91 accord ex Auto to Manual swap
Originally posted by srt4man00 View Postabsolutely .. bolts right up but why get rid of the vtec. 93 lx no vtec
first of all the cb7 ex's did not have vtec. the cd5 was the first accord in the U.S. to get vtec. now yes the engine and trans will bolt up but the swap to a standard will take some extra work. you will need the axles off the 93, the halfshaft, and all the transmission and hydraulic components. you will also want the ecu, get rid of the tcu, and swap dashes. its not the easiest thing to do though.
why are you swapping? is your 93 wrecked?
No you google it. if it has vtec then it has a newer motor that was swapped into it. there is not a single 90-93 accord in the us that came with a vtec engine. they are the f22ax series. f22a1, f22a4, and f22a6, none of which have vtec. the f22a6 has a more agressive cam and IAB intake manifold but no vtec.
that 91 ex he has does not have vtec unless it has swapped in motor. your friends must also be swapped. tell me this. find the engine code on the block to the left of the exhuast manifold and tell me what it says.
and by the way: OP sorry for this and i apologize. this is the section for 94-97 accords. you would probably have greater luck in the future in the cb7 forums below these on the main page. as i stand though your swap is possible.
Originally posted by srt4man00 View Postlook even my mothers 91 accord ex had vtec.. it might not be there in big ol letter or anything but take a ride in one and listen for the pop.. wont be a big one like the h22 or gsr but theres definetly vtec
Originally posted by MotorButt View PostI just got a 1991 honda accord ex coupe thats auto but I have a 93 accord lx, I was wondering if its possible that I can swap my engine, tranny and 5 speed into the 91 accord ?
The tranny swap will take a lil more effort since you have to completly remove the auto tranny and all its coolant lines, then you gotta run clutch pedal, clutch line and blah blah blah, its some work but its well worth the effort in the end
look even my mothers 91 accord ex had vtec.. it might not be there in big ol letter or anything but take a ride in one and listen for the pop.. wont be a big one like the h22 or gsr but theres definetly vtecLast edited by 904drACCORDMANG; 07-25-2010, 12:46 AM.
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
Originally posted by 90accords View Postall correct..... cept it isn't necessay to swap the dash out.... the cluster IF you want the manual one but also not necessary. ECU from the 91 will work as is, and you can simply unplug the tcu.....
There is no VTEC on any 90-93 Accords, and there is a full thread on what to do and how to do the auto to 5 speed swap in the DIY section.Current:
2007 Acura TL Type-S 6MT KBP
Past:
1992 Honda Accord EX-R Sedan - RIP
1991 Honda Accord EX-R Wagon - RIP 10/14/2010
Words change lives. You just got to choose the right ones.
Instagram: @CB7Nub
Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
