Car is a 92 with an F22A1 and an auto transaxle.
My problem is that after installing a new distributor I cannot get the ignition timing back whete it should be. There isn't enough play in the distributor to rotate it far enough towards the radiator. When rotated all the way towards the front of the car the tip of the area on the flywheel where the timing marks are is just above the pointer.
That means that the car is running, but it lacks acceleration.
It wasn't like this before I swapped dizzys, and it's the same no matter what dizzy I put in. Any ideas would be appreciated.
