i removed my old original factory headers (removing the nuts from header to downpipe was extremely difficult, took me awhile) and i'm trying to install these 4-2-1 headers. i believe they're a4 headers. when i try to sit them in the engine bay there isn't enough space for them to line up with the studs from the head because of other parts in the way. power steer bracket, the front motor mount, the thermostat, the AC hose thingy that's pressurized(don't know the name for it sorry). my question is what would you recommend for me to remove in order for the headers to be applied? in other words which one would give me the least hassle?...
f22a1 header fitting..
thank u guys for the info, and yes i have been patient. i've tried multiple ways for the header to sit in properly over the past 3 days but there's always something in the way that prevents it. i just removed the thermostat right now and it helped a little, although the far right edge tip of the front motor mount is still blocking it from sitting in.
so now my only options are to remove the power steering bracket or the motor mount.
i'm going with jacking up the motor a lil bit and removing the mount...RIP '91 LX.
yeah i loosened the motor mount bolt n the header sat in. i put everything back together. i changed the oil pan gasket earlier before all this, so i did an oil change and added BG MOA. i'm still an amateur at this "diy" type of thing and have another question. did your new headers smoke up a lil bit while ur engine was running after the install?RIP '91 LX.
Originally posted by youngflyndsaved View Postyeah i loosened the motor mount bolt n the header sat in. i put everything back together. i changed the oil pan gasket earlier before all this, so i did an oil change and added BG MOA. i'm still an amateur at this "diy" type of thing and have another question. did your new header smoke up a lil bit while ur engine was running after the install?
thanks for info i appreciate it! i was cautious at first about but i thought that might have been the problem. i shut them off after i let it run for a lil, then i started it back up n it stopped smoking.
that's one thing diy threads should warn u about, the after effects of installs and things like that. i remember when i replaced my spark plug tube seals and after i started my motor back up i heard clicking noises and i panicked and thought i did something wrong... it was just the camshaft and rocker arms didn't build up oil yet so the contact created noise.
on another note it sounds beautifuLL with the new headers when i rev..!!!RIP '91 LX.
