EG Civic Coupe 95
    EG Civic Coupe 95
    So ya'll, since my cb9 was totalled in a crash last Fall, I decided to get me a civic and what I plan to do is a H23 Vtec swap. I already have the complete engine from the wrecked cb, and I was reading and seems this swap isn't that hard to do. Do you guys have any pointers on doing the swap tho? I got a swap mount kit in mind, its one where I don't have to mess with the chassis too much to do it. Its a cheap kit (Yokana) but I think it will work fine.
    I don't have pics as of now but I will soon.
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
    ― Jeremy Clarkson
    the injectors wont really work, they are obd2/bosch style. the distributor wont work either, the iacv wont work. your best bet it to get a euro-r/skunk2/obd1 h22 intake manifold/ injectors, distributor. keep the h23vtec throttle body. You can use the f22 fuel rail. everything is straight forward
