Ok guys i have a 92 lx auto f22a1. problem, no reverse or 4th gear. i think its internal but ive had some people say its the shift silonoid. i know its not the tcm i switched it out and the same problem persists. it all started after i had two of my trans coolant lines bust (they had clean cuts in them it was weird). all the fluid had come out and i was going about 50 and i tried to hit the gas nothing just rev, i coasted to a stop after puting it in nuetral. i let it sit and did the repairs the next day. ever since it sliped when going into fourth and got worst as time went on reving to about 3 grand befor finally catching. then one morning i tried to go into reverse and it just reved it would shift if i slowly reved and let it sit at four grand for just a second not too long. But now (6 to 7 months later) there is no reverse and no 4th, also when shifting into second it shutters VIOLENTLY hard and 3rd is sound like 4th used to (the sliping i mean). please if anyone has any good advice let me know. pm me if youd like. thanks.
Trans problem..HELP
damn
sheeeeeeeeeeeeeeettttttt that kinda sucks eh?
sounds like you completely euchered yer tranny.
get yer arse to the wreckers and grab one before there are none left.
easy peasy to swap it out.
if you can, remove it from the wrecked car yerself..that is yer LEARNING model and then you'll be experienced once it comes time to do yer car.
GOOD LUCKYEP. I AM Canadian.
1990 Accord EX 220,000 KM. Essentially stock with 15" alloys and chin spoiler added. K&N filter and Bosch plugs. ICE COLD A/C which I love!
1992 white EX 4 dr, 5 spd. (602,000 Kms and I JUST RETIRED IT. SO SAD!) DEC 9TH, 2005 - MAY 31, 2012. I added 229,000 kms to it. Great car!
You could also keep an eye out on here for someone local that is doing a manual conversion... that way, you'd know the transmission came from a running car. With a junker, you never know if that is the reason the car is there! Find one with rear end damage, or a side impact... at least then you'd know the car was probably on the road when it met it's end, rather than sitting due to mechanical failure.
I must say... good job on the post! This is how questions SHOULD be! "Help, I'm stuck. Here is what I tried, here is what I think the problem is, where do I go from there?"
I see too many "my tranny dont work wuts rong?" questions... It getts irritating!
Good luck man!
well, good luck on finding a tranny...too bad u had to let that other go....if u need a job, Dairy Queen oin Calgary pays 12 bucks per hour TO START...benefits, too.
Come on up EH.YEP. I AM Canadian.
