I need help with my headlights!
    Hello everyone... I own a 1992 Accord EX. I picked it up for $300 with 375,000KMs... I sold my 87' IROC last week. This only has to last me the winter. Anywho, there's nothing too major wrong except the headlights... as soon as you put a 20fuse into the left headlight and turn the light knob 2 times, it blows. The headlights/highbeams don't come on at all either way. That's where I'm at. Is it more likely for the short to be at one of the ends rather then in the middle of the wires? I have no clue where to start and I know it would be costly to get it done at a shop. Could I rewire it easily? Thanks!
    You need to find where that short is. Could be a dumbass rat chewed it somewhere , and been touching bare metal.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      Alright.... but since it only blows when the highbeams are turned on is there a chance of the lowbeams still working working or would the short in the highbeams disable them? I'm pretty sure the bulbs I took out were bad.
      Here's some pictures of what I'm working with...
      On the right side (passenger side) there's the obvious highbeam light and then a broken plug that barely reaches where its at now(worrys me). Is that the lowbeam plug?
      and the left side I have 3 plugs... the obvious highbeams (which runs infront of the rad and around the battery) and then 2 more. What is the white plug for?
        wtf is going on here, white is low, blue is high, why do you have two?
        wat?
          That's where I'm confused... I think someone may have tampered with the electrical during a previous time..
            You've only spent $300. Spend $15 more and get a manual with a wiring chart (there are some online) and trace the wires to find your short. It'll be worth your money.
            90 Accord Ex, F22A4. Slight fire damage.
              I found out whats happened... somewhere in the left wiring there's a short. Seems like the people before me couldn't find it either and purchased another headlight connector, wiring it into the right headlight wires and ran it across the rad. After I repaired the shawty connecting they did and replaced the bulbs. They both work on the right 20 AMP fuse.. is this ok for the time being or are they not going to be as bright?
                Assuming the headlamps pull less than 20 amps (and I doubt they pull more than 5) they will be just as bright running off that right circuit as they would be off the left. But that circuit will have 2x the amperage running through it than it normally would. As long as that is below the threshold for the fuse it should be ok though. Depending on the gauge of the wires there might be more heat generated in the wire because of increased amperage but I'm pretty sure (although I'm not an electrician by any stretch of the imagination) that would be minimal and no cause for concern.
                  You still have to find and remove that short. Cut the headlight wire in half (half the distance to the light itself) and test each side of the wire for continuity with one test lead on the car chassis and one on the wire section you are testing. If you get continuity then the short is in that half. Replace the wire section that is shorted. Or just replace the whole wire.
                  At the minimum, cut and cap the left circuit near the console light switch to prevent power from going through it and shorting in the future.
