Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 04-26-2005, 06:07 PM   #41
timmy0tool
Accord of the Month: April 2006
timmy0tool is cool... so far.
Send a message via AIM to timmy0tool
you can replace just the dust boot? i thought you should replace the whole balljoint?! how do you replace just the dust boot and grease?
1cor10:31
- 92 LX coupe
- 96 EX wagon (sold)
timmy0tool is offline   Reply With Quote
Old 04-26-2005, 08:09 PM   #42
BustedLX
BustedLX is cool... so far.
You can just replace the dust boot and pack some grease in there but if you have been riding on torn boots for awhile you should replace the whole joint. Reason is that dirt gets in there and damages the ball and socket of the joint.
BustedLX is offline   Reply With Quote
Old 04-29-2005, 01:35 PM   #43
ObieWanCoyote
ObieWanCoyote is cool... so far.
Busted... So what parts would you recomend for the front swap? Sounds like everything is a direct swap from a `97-01 Odyssey?
What calipers will work (front and rear)?
And what bolt pattern are the new hubs if you recall off hand.
Mahalo -Coyote (`91 ex coupe stuck w/ stock drums in the rear)
ObieWanCoyote is offline   Reply With Quote
Old 04-30-2005, 03:40 PM   #44
timmy0tool
for the front you can use everything that comes with the knuckles of the odyssey. this means the calipers and rotors as well. you can also use prelude VTEC calipers (doesn't matter what year just as long as it came from a VTEC prelude), legend calipers (like busted's setup), and even NSX calipers if you can get your hands on them. basically anything that is compatible with 11" rotor can be used.
as of now, you can only use the accord calipers in the rear. i haven't seen any other caliper swap...yet. i'm sure someone will be able to swap something else in there.
bolt pattern is 5x114.3mm. i learned this the hard way !
1cor10:31
- 92 LX coupe
Old 04-30-2005, 05:14 PM   #45
k-mart
k-mart is cool... so far.
possibly the 97+ ITR caliper possibly, right? since the rear pads for the cb7 and ITR are the same part number, could you assume that the calipers are interchangable? i dont think that would necessarily be an "upgrade" but that goes the same for the 5th gen accord rear calipers.
k-mart is offline   Reply With Quote
Old 05-02-2005, 07:14 AM   #46
jdm-cb7
jdm-cb7 is cool... so far.
what year of oddysey suspension you used?
91 cb7 coupe sold
92 CB7 sedan sold
91 cb7 sedan current
jdm-cb7 is offline   Reply With Quote
Old 05-02-2005, 07:51 AM   #47
k-mart
95-98, but that only applies to the front conversion
Old 05-23-2005, 12:57 AM   #48
timmy0tool
busted, just like doing a rotor over hub conversion, can you use let's say a 97-up prelude hub for the 5-lug up front?! can it fit inside the accord bearing? why change the whole knuckle? just a thought since i was looking over the hub conversion and the 5-lug idea came about. is this possible?
1cor10:31
- 92 LX coupe
Old 06-03-2005, 09:42 PM   #49
BustedLX
5-lug Honda vehicles rock an 85mm bearing and 4-lug rock an 80mm bearing so the opening in the knuckle is not big enough to accept the larger diameter bearing.
Old 07-13-2005, 01:59 AM   #50
JG_H23_CB7
JG_H23_CB7 is cool... so far.
Send a message via AIM to JG_H23_CB7 Send a message via MSN to JG_H23_CB7
Great Job Bust.
Hey now, My signature was too big, so it was deleted.
JG_H23_CB7 is offline   Reply With Quote
Old 01-04-2008, 07:06 PM   #51
slammed90ex-r
slammed90ex-r is cool... so far.
how much different is the nut for the the prelude compaired to the accord
i just put the prelude brg on the rear and with the accord nut it only goes on with 4 threads. so the prelude nut should fix this?
slammed90ex-r is offline   Reply With Quote
Old 01-15-2008, 03:29 PM   #52
HenRoc
Black Thunder
HenRoc seems to have made some friends! HenRoc seems to have made some friends!
Send a message via AIM to HenRoc
From what he had written about the DYI is that you could can use the Prelude spindle nut for the back with no problem at all and you'd need to do is make sure you hit it hard and stake it securely in that slot.
Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
HenRoc is offline   Reply With Quote
Old 01-15-2008, 06:27 PM   #53
2.2litrebeater
2.2litrebeater is cool... so far.
the prelude nut still doesnt go on all the way, but i was able to get it on enough to stake it and so far its been fine
FA1
355
2.2litrebeater is offline   Reply With Quote
Old 02-10-2008, 07:25 AM   #54
excalibur02
Wanna be JDM whore
bump since most people are asking for info and are interested to go 5 lug
Instagram username MAURO02
Old 04-05-2008, 04:57 PM   #55
ILoveMyHonda
ILoveMyHonda is cool... so far.
Bump! Nice DIY.
Question: Would I be able to do this swap if I purchased the "rear disc conversion" from TAS? Or would I have to do an OEM rear disc swap?
'91 Cobalt Sedan w/ 300k (owned since new, moddin' it since '98)
www.tsxclub.com
ILoveMyHonda is offline   Reply With Quote
Old 05-29-2008, 03:47 PM   #56
i-07
i-07 is cool... so far.
Send a message via AIM to i-07 Send a message via MSN to i-07 Send a message via Skype™ to i-07
so this will be fun so i got to go get the EX rear disc setup put it on then get the list o parts cool.
back at it again
i-07 is offline   Reply With Quote
Old 07-30-2008, 07:15 PM   #57
Straight Success
Straight Success is someone to admire Straight Success is someone to admire Straight Success is someone to admire
I always meant to ask. Why did you use the ITR rotors and not the prelude ones.
The Lord watches over me!
Straight Success is offline   Reply With Quote
Old 08-01-2008, 11:41 PM   #58
Straight Success
Bump for answer. I know it was said the Prelude rotors wont work. Why not?
Old 08-01-2008, 11:48 PM   #59
Straight Success
Is it because the prelude rotor isn't tall enough, so it wont fit on all the way?
Old 08-05-2008, 08:22 PM   #60
slammed90ex-r
the rotor doesnt go in far enough so it will not fit with the stock accord caliper bracket.
there is a way of using the prelude rotor you just need to make a spacer to space the caliper out toward the rotor that way the caliper will be centered over the rotor that is what i did
