Thread Tools Rating: Thread Rating: 27 votes, 5.00 average. Display Modes
Old 04-23-2008, 06:26 PM   #81
preludeman92
preludeman92 is cool... so far.
I'm curious, has anyone tried doing this with 4th gen prelude stuff?
The knuckles are identical, but use 4 lug stuff that matchs what's on our accords already... that way if you've got some 4lug rims you're in love with, you can still use them. Plus, you can use non-vtec prelude stuff and still use 14" steelies and get rotor over hub for easy brake work.
preludeman92 is offline   Reply With Quote
Old 11-18-2008, 04:17 PM   #82
gloryaccordy
I have a friend with a Prelude Si who I might snag front knuckles from....
Old 11-20-2008, 10:22 PM   #83
KRIS05VVTi
KRIS05VVTi is cool... so far.
Send a message via AIM to KRIS05VVTi Send a message via MSN to KRIS05VVTi
thanx dude this is wat i needes =]
Purchased from: 90-JDMCB7, cb95spd, 92_dr_p, ukaccord92, slammed4thgen, 93a-lude, h22anow, cb7addicted, H22WAGON93, tonymontana1204, agol, Joshy
Sold to: di2accord
KRIS05VVTi is offline   Reply With Quote
Old 12-03-2008, 11:48 AM   #84
gloryaccordy
OK scratch my prior questions...
Will a BB6 front crossmember bolt up to our car?
Also, if so, would using a BB6 front crossmember, LCAs and obviously knuckles put the front wheels at a weird angle/placement?
LMK!!!
Old 12-03-2008, 06:29 PM   #85
excalibur02
Wanna be JDM whore
LMK!!!
thats to much work to just go 5 lug!
Yaw, you just should do the enlarging of the accord LCA with SPC upper ball joint camber kit or go odyssey...
I know typesbaby's bf bought the full bb6 front crossmember and LCAs. I am not sure what he did with it.
maury
Instagram username MAURO02
Old 12-03-2008, 08:58 PM   #86
gloryaccordy
maury
Yep, enlarging the Accord hole will be the best deal, though with it out, it will be a good time to compare Accord & BB6 LCAs...
Old 12-03-2008, 09:05 PM   #87
djcaz_aom
djcaz_aom seems to have made some friends! djcaz_aom seems to have made some friends!
I can take pics of both LCAs tomorrow.
djcaz_aom is offline   Reply With Quote
Old 12-08-2008, 08:28 AM   #88
gloryaccordy
Just a heads up... when u go to get ur knuckles, the way to tell they're SH knuckles is that they have 2 LBJs.
However, all is not lost; if you get them for a good price the whole assembly is still useful.
Why?
BB6 base + SH bearings + hubs are the same. (Part # 30892)
BB4 knuckles accept BB6 hubs; in fact BB4 knuckles basically look the same as BB6 base knuckles (diff part #s, little differences like a balljoint cap on the BB4 knuckle & a knuckle "ring" on the BB4; might be on both though & just comes w/the BB6 knuckle)
BB6
BB4
Originally Posted by warrick View Post
Well I finally got the 5 bolt done. I ended up having to press out the 5 bolt hubs and press them back into the 4 bolt knuckles. As for the back I ended up having to purchase the rear calipers from a 5th gen for them to bolt up.
So ya just a heads up for anyone else doing this conversion. I will post pics in a couple of days.
Easiest easiest easiest easiest cheapest way though would just be to find some Odyssey hubs and bolt them up to the CB knuckle; for all the trouble I wish I had gone that route.
Old 12-08-2008, 10:20 AM   #89
djcaz_aom
So we can use BB4 knuckles and have the ability to change out lower balljoints when needed then. Hmmm...
Old 12-08-2008, 10:39 AM   #90
90accords
90accords is cool... so far.
well in my process of doing this, I ended up with this tool:
same degree of taper as the prelude balljoint. I used the knuckles from a 99 prelude and used the tool to enlarge the LCA hole on my accord. It's a nice tight press fit like stock. Also, during my research, I ran across the part number for the bb6 lower ball joint : 51220-SL5-013. It's the same one they use on the later model Legends.
90accords is offline   Reply With Quote
Old 12-08-2008, 10:43 AM   #91
gloryaccordy
Cha-ching, as DocCiph would say; however I don't see why if you can change BB4 LBJs you can't change BB6 LBJs... look @ the diagram, the LBJ arrangement is the same.
Old 12-08-2008, 12:13 PM   #92
excalibur02
Wanna be JDM whore
I could of told you that from the get go! When ever some one asks about the 5 lug if you have the choice from APW and Odyssey I would prefer Odyssey since its much easier!
Dont get me wrong the all prelude way is fine but just takes more work.
thats good news right there. Next year I will def replace them just for safe measures!
Old 12-08-2008, 01:40 PM   #93
gloryaccordy
If there were a way to get cheap Odyssey hubs... i.e., if there were an aftermarket seller of them that made them for ~150 a pair, *busts nut*... Honda wants too much for them, u can get a lot for ~250.
Old 12-08-2008, 11:20 PM   #94
djcaz_aom
Right on that; good luck finding the lower balljoint for the BB6 though.
A couple posts up mentions a part number for a balljoint. Will have to investigate.
Old 12-08-2008, 11:40 PM   #95
djcaz_aom
Okay I checked that part number and came up with this:
97 and 98 BB6 front knuckles share lower ball joints with the BB4 and 91-95 Legends.
Interesting stuff. They must have changed something in 99? Hmmm...
Old 12-09-2008, 08:07 AM   #96
gloryaccordy
There is a part number for them; they are weird though, they only sell it in pieces it looks like.
Old 12-09-2008, 03:29 PM   #97
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
ive heard mention that the lude balljoints are not removable, but you can replace the boots. this doenst make logical sense, but that really may be the case...
Old 12-09-2008, 10:45 PM   #98
djcaz_aom
They look like they are just pressed in to me.
I will have to investigate more on this.
Old 12-09-2008, 11:08 PM   #99
JaK FRoSTWhiTE
Event Staff
JaK FRoSTWhiTE is cool... so far.
Send a message via AIM to JaK FRoSTWhiTE
I replaced the LBJ on my lude knuckle.
JaK FRoSTWhiTE is offline   Reply With Quote
Old 12-09-2008, 11:42 PM   #100
The G-Man
The G-Man seems to have made some friends!
Send a message via AIM to The G-Man
I am pretty sure you can't do this because the wheel bearing is different.
Gary A.K.A. Carter
[sig killed by photobucket]
The G-Man is offline   Reply With Quote
