Best cheap suspension?
    Originally posted by cb9love View Post
    i clearly stated they came off a acura cl which is close enough too a accord and is one of the cars used on this forum for brake swaps so your saying the cl is good enough too stop us but not good enough too hold us up ?
    the cl weighs more and on the strut and spring web sites they are listed as cl or accord
    CB7TUNER.com
      Also KYB makes oem replacement parts but they also make upgrades such as the gr2's sitting on my car now that came with eiabch springs as a package, listed for cl/accord my just happen to come off a cl that was in a junk yard. Suspension wise there is less difference between CL/Accord then there is between integras/civic and most of us know how much of that interchanges. Do the research then go pick your parts, do not worry what one person says you can do or can not do, do the research try fitting parts enjoy your car.
      CB7TUNER.com
        Originally posted by steelbluesleepR View Post
        on that same website, you can get Koni STR-T's all around (a much better shock than Tokico's) for $273 and H&R Race or sport springs for $240. That setup will lower it 2" (for the races) or 1.5-1.75" (for the sports) for a total of $513 plus shipping.
        for $100 more, you can grab a set of ground control coilover sleeves and get height adjustability with quality springs.
        To take corners better, you are going to want at least an upgraded rear sway bar. The progress is the stiffest one you can get for our chassis and it eliminates most if not all understeer and body roll.
        For a tower bar, I would look up the "Sprint" strut tower bar on ebay, they are about $45 and are the same solid-mount design as the now-discontinued Neuspeed bar.
        H&R Races would rape those struts
        Def keep it Sport
        Originally posted by lordoja
          your life not mine im done.
          this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
          Car safety checks
          Fluid Capacities
            That wasnt an official package from KYB...
            I could open an eBay store selling sleeves on stock shocks... that doesnt mean thats a good combo
            Stop being a fucking cheap ass, you are diluting the quality of CB builds and a danger to the public.
              reading through the suspension link posted. added up to 450 when you could get f/f type 1's for 599. almost worth the extra 150 in my opinon to go full coils
                I'd rather have quality springs/shocks over cheap full coilovers, personally. I don't have the need, knowledge, or tools to properly adjust coilovers.
