Here is how to make the h4 funtion as a high and low beam working together with the h1 bulb, and its not on all the time just like it should be.
jdm headlight FAQ w/ answers!
This is a sticky topic.
Retro!
Hater
power, low ground, high ground is right. hehe i thought it was power, low ground...and high power but obviously it didnt work lol!
why didnt you want the high and low to get power? mine is separate, if i turn the highs on the high beams actually turn on the h4 and if i turn it off it just is standard.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztechpower, low ground, high ground is right. hehe i thought it was power, low ground...and high power but obviously it didnt work lol!
you do know i wired it up normal right? aha. like low beam its only low beam, and high on the h4 it is the high on that bulb...rite? i dont use the high beams for more than 5 minutes at most anyways and also i put a higher upgraded harness =)What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztechyou do know i wired it up normal right? aha. like low beam its only low beam, and high on the h4 it is the high on that bulb...rite? i dont use the high beams for more than 5 minutes at most anyways and also i put a higher upgraded harness =)
hahah yea they do.
its hard to explain unless you understand how a relay works, its just like a mini switch.
85+86 is the switch. one is always going to get positive and the other is going to get negitive allowing whatever is at pin 30 to go to pin 87. think of it as a door, 85+86 will open the door for the pin 30 to go to the 87.
in this case, i used the positive and negitive from the high beam (it only does pos and neg when the high is on and not when its off) to trigger the switch. pin 30 is grounded to the high beam ground, so that signal goes directly to pin 87 as a ground to turn on the h4 high beam.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
i know this may sound dumb but has anyone convertered the h4/h1 to 9005/9006 due to the fact i already purchased hids for my 90 accord ..... i might purchase a set of jdm 1 piece headlight for my accord but i now realized that there h4/h1 is there anyway around this? custom fit the rear socket to 9005/9006?
1992 H22A4 Coupe - R.I.P.
Bought from: slammed4thgen. new_beginnings. crzy.tuning. f20aaccordturbo. hondaguy1212. cb4_honda. fatboy1185. wed3k.
_____________H22A4CB7. minorreparations. PR CB7. plee3. Bisimoto Engineering.
Sold to: LadyG. sulimed. choppacity. choogee3.
Originally posted by SE_DynamiK View Post
they sell all 4 right there in one package.
i bought myself a set; saves a hell of a lot of trouble.
i think it came up to ~45$ shipped1992 H22A4 Coupe - R.I.P.
