Thread Tools Rating: Thread Rating: 6 votes, 1.00 average. Display Modes
Old 04-10-2012, 10:38 PM   #21
GhostAccord
CB7tuner Member
GhostAccord seems to have made some friends! GhostAccord seems to have made some friends!
If he is using an F23 intake and F23 fuel rail, It would be easier just to get some taller injector bushings.
and there are taller lower bushings/seals as well. Using the two easily makes up the 1/4" difference. Depends on which is cheaper I guess.
__________________
MR Thread
GhostAccord 2.4L Blog
by Chappy, on Flickr
GhostAccord is offline   Reply With Quote
Old 04-10-2012, 11:05 PM   #22
jaemil369
CB7tuner Member
jaemil369 is cool... so far.
I need to go lower with bushing if I go that way or raised mounting bolts. I tried to put f22a fuel rail on but the mount holes on the rails are different. I was gonna drill but nowhere to unless I go in the rail where the fuel feeds thro.
jaemil369 is offline   Reply With Quote
Old 04-10-2012, 11:12 PM   #23
GhostAccord
CB7tuner Member
Oh yeah...sorry about that... Shims on rail mounts = using lower bushings.
__________________
MR Thread
Old 04-11-2012, 01:52 AM   #24
jaemil369
CB7tuner Member
Lol its alright, I appreciate your help tho man...you too deeves not to mention everyone else but had to spotlight deeves for a min, he knows why lol
Old 04-11-2012, 08:55 AM   #25
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
Sorry, I was grumpy last night, and I was also wrong... Glad GhostAccord is here to set things right!
__________________
deevergote is offline   Reply With Quote
Old 04-11-2012, 12:10 PM   #26
jaemil369
CB7tuner Member
Shit happens lol. I appreciate everyone's help, input, and suggestions
Old 04-12-2012, 05:08 PM   #27
jaemil369
CB7tuner Member
This is just to clear some things up and maybe help someone in the future.
This is the f22a1 fuel rail on the f23a1 intake mani. As you can see it doesn't mount the same.
This is the f23 fuel rail with f22a injectors, due to different plugs on the injectors they have to be use with this part of the f22 harness. As you can see it wont sit down all the way.
So in this case I have to shim the mounting bolts up enough to get a good bit to hold it securely without leaks.
Old 04-12-2012, 05:39 PM   #28
dj_ender
Mod\Dubstep Pusher
dj_ender seems to have made some friends! dj_ender seems to have made some friends!
Are the shafts for the F22 fuel rail longer? Maybe you swap them and they will extend enough.
__________________
Quote:
Originally Posted by Mishakol129 View Post
dj_ender is offline   Reply With Quote
Old 04-12-2012, 05:48 PM   #29
jaemil369
CB7tuner Member
Shafts? As in the mounting bolts? If so they are different all together
Old 04-12-2012, 05:50 PM   #30
dj_ender
Mod\Dubstep Pusher
Quote:
Yes the mounting bolts. Im saying can you swap the ones off the F22 IM to the F23 IM and will they be longer?
__________________
Old 04-12-2012, 05:59 PM   #31
jaemil369
CB7tuner Member
No, they do not detach from the intake mani
Old 04-12-2012, 06:00 PM   #32
dj_ender
Mod\Dubstep Pusher
Doh! I forgot they are studs. So much for that idea.
__________________
Old 04-12-2012, 06:04 PM   #33
jaemil369
CB7tuner Member
Yea lol, so I'm going to get some lock washers to shim them up accordingly
Old 04-12-2012, 06:07 PM   #34
dj_ender
Mod\Dubstep Pusher
I wonder if the rear valve cover studs will work... Sorry just trying to help you brainstorm.
__________________
Old 04-12-2012, 06:12 PM   #35
jaemil369
CB7tuner Member
Hum...that's thoughtful. Ill definitely check the out tomorrow, thanks
Old 04-12-2012, 06:17 PM   #36
dj_ender
Mod\Dubstep Pusher
No worries, figured if you already have a F22 head your not gonna use, you could take them out and try them. The intake side ones are the longest.
__________________
Tags
f22 , f23 , fuelrail , honda , swap
