Go Back   CB7Tuner Forums > Site Features > DIYs > Suspension DIYs
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 05-24-2011, 06:28 AM   #101
CB7North
CB7tuner Member
CB7North is cool... so far.
i jus did mine last night took me about 7 hours to do it .. it is easy but if u have rust like me it a bitch!
CB7North is offline   Reply With Quote
Old 10-08-2011, 12:05 PM   #102
91cblx
CB7tuner Member
91cblx is cool... so far.
Send a message via AIM to 91cblx
bumpin and old thread but my questions is how do I make sure the splines on the rack and pinion go straight in on the steering column shaft? I want to make sure I get the rack centered and make sure my wheel is straight. I don't want my wheel to turn sharper one way than the other lol.
91cblx is offline   Reply With Quote
Old 02-09-2012, 11:24 AM   #103
Bad_dude
CB7tuner Member
Bad_dude seems to have made some friends! Bad_dude seems to have made some friends!
Question
I don't need to replace the rack yet but could you use the first part of the DIY to change your power steering fluid? Would an empty system hurt the pump?
Thanks.
Bad_dude is offline   Reply With Quote
Old 05-10-2013, 06:05 PM   #104
P5ylance
CB7tuner Member
P5ylance is someone to admire P5ylance is someone to admire P5ylance is someone to admire
One bolt near the Power Steering stuff (not the bracket side) is stripped, and so is the hole that it bolts into... Is the hole that it bolts into directly in the chassis, or is it bolted into a piece that can be removed? I'm trying to figure out what to do about the stripped bolt and hole. I've heard of the brand Heli-Coil, but don't know what exactly to do with it. would i need to remove the R/P to install a Heli-coil threaded insert? guidance, please! thanks!
Second Question: There are tubes connecting to the dust boots. I replaced the boot on the drivers side, but the tube is difficult to re-attach since it is very short. what is this tube for, and is it important? I understand you should always reconnect things, however, this tube was connected to a torn boot, and thus was exposed to air and all sorts of stuff so not re-connecting it is the same as its previous condition and nothing bad really occurred.
__________________
P5ylance is offline   Reply With Quote
Old 05-23-2013, 10:01 PM   #105
schierholz
CB7tuner Member
schierholz is cool... so far.
I have to know if I need any new gaskets or seals the hanger is a year old the rack mount is a year and a half old do I need a gasket for the ehaust ?
__________________
Quote:
Originally Posted by evil_demon_01 View Post
Do it once, do it right.
Saving a dollar is not worth risking a life.
Missing My
White -91 LX Sedan - leather converted
Mulberry 91 EX Sedan
The project 92
schierholz is offline   Reply With Quote
Old 05-24-2013, 01:08 PM   #106
P5ylance
CB7tuner Member
Quote:
when you take it apart? it wouldn't hurt. the exhaust hanger should be fine, as long as its not cracked or damaged (i think i'm still running the OEM ones after all this time )
the gasket shouldn't cost too much to replace. IMO, I would do it just so that there won't be any complications, if any, later (like leaks or whatnot).
__________________
Old 05-25-2013, 12:11 AM   #107
schierholz
CB7tuner Member
Yes when I pull the rack I just wonder how many gaskets I need I will look into majestic.
__________________
Missing My
The project 92
Old 07-21-2013, 02:40 AM   #108
laloquera
CB7tuner Member
laloquera is cool... so far.
Bump, bump & bumpity bump. Thanks for the DIY, I am getting started on this job first thing in morning. I am dealing with one exhaust pipe from header to muffler. Also, poor bastard so I am pulling my r&p from a local junk yard. Wish me luck and will post up my results.
laloquera is offline   Reply With Quote
Old 09-01-2013, 12:59 AM   #109
Tabor
CB7tuner Member
Tabor is cool... so far.
Quote:
The tube is important. It moves air from one boot to the other (when you turn). I don't know exactly why that is necessary, but all R&P units that I have ever seen have one.
Tabor is offline   Reply With Quote
Old 09-13-2013, 12:25 AM   #110
Tabor
CB7tuner Member
I just thought that I should add that:
1. It is way easier to move the hard power steering lines out of the way if you disconnect your sway bar end links and drop the driver's side of the sway bar by unbolting it from the chassis (this is a good time to replace your end links and bushings).
2. You should really uses flare nut wrenches for disconnecting the hard lines.
3. You definitely want to turn the steering wheel all the way to the left as to move the driver's side tie rod in and the passenger's side out.
__________________
1991 LX Wagon
Old 09-13-2013, 12:41 AM   #111
bobbycos
Contributing Member
bobbycos seems to have made some friends! bobbycos seems to have made some friends!
Send a message via AIM to bobbycos
available at any auto parts store or Harbor Freight tools
dumbass me stripped a flare nut on my old Impala and had to buy a new hose AND the properflare nut wrenches
bobbycos is offline   Reply With Quote
Old 09-07-2015, 10:29 AM   #112
Accord1320
CB7tuner Member
Accord1320 seems to have made some friends! Accord1320 seems to have made some friends!
Here's my rack and pinion vids...
Part 1: https://www.youtube.com/watch?v=VWqV5Jb_-wM
Part 2: https://www.youtube.com/watch?v=4xO3VDdLHLM
Hope this helps a bit...
__________________
"There are only two types of people in this world... Those who run & win, and those who sit at the sidelines & watch the winners pass them by."
My YouTube Channel! - There's more videos here!
Check 'em out, hit LIKE, or even better, stay updated with more vids when you SUBSCRIBE, including vids of my JDM H23A swap!
Accord1320 is offline   Reply With Quote
Old 01-20-2016, 11:02 PM   #113
bobbycos
Contributing Member
Necroposting
I have a bad inner tie rod and need to know the proper size of the crowsfoot style wrench needed to remove it
Old 03-05-2016, 08:17 PM   #114
fleetw00d
Contributing Member
Quote:
Originally Posted by bobbycos View Post
Necroposting
17 mm
__________________
90 LX 4dr 5 spd 385,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 192,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
