Old 01-19-2015, 10:16 PM   #1
demigtod
Newcomer
demigtod is cool... so far.
Exclamation help with diagnose my problem
so this past saturday i was driving my 91 ex and was running just fine. i got home and shut it off and went to move it about 3 hours later, all it would do is turn over. well i had new spark plugs, ngk, ive been waiting to install, so i put those in along with new wires. right off still would not start. so i had some one try to start it to check for spark. it fired right up with out a problem, i let it run for about 5 minutes and no problem.
i went out the next morning it did not start again. i again checked for spark and its there. i have changed out the cap and rotor. ive tried a couple other main relays. everytime trying to start it i can smell fuel coming out the exhaust. when i go to prime it i can hear to click from the main relay. i did try starting it with starter fluid, it will start up and run just fine until the starter fluid is gone, then shuts off.
i cant think of anything else to check.
demigtod is offline   Reply With Quote
Old 01-19-2015, 10:23 PM   #2
fleetw00d
Contributing Member
Check the fuel pressure at the left end (driver side) of the fuel rail. Depending on the year and model, it should be in the 30-40 psi range. If low, change the fuel filter. If still low, pinch off the fuel return line, the pressure should go to about 60. If still low, you probably need a pump (in the tank).
Are you installing used relays, or known good (new) ones?
__________________
I'm down to one CB, going through withdrawal DTs
90 LX 4dr 5 spd 383,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 189,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
INVENTORY REDUCTION! LOTS of CB7 parts - make me an offer http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 01-19-2015, 10:33 PM   #3
demigtod
Newcomer
jy ones
Old 01-19-2015, 11:36 PM   #4
johnl
CB7tuner Member
johnl seems to have made some friends!
I expect a moderator will jump on this thread soon if you don't change your title to something a bit more descriptive of your problem...
Thank you for using punctuation, but capitals would also make it easier to read your post. The lack of capitals isn't helping my headache...
__________________
Regards from Oz,
John.
johnl is offline   Reply With Quote
