I can't get the photo's to come up...Too big ...So I'm going to try to put it on my site www.accordobsession.com. (I think you have to register to see posts...sorry) and it took a sec to put in and YES IT IS THE FIX!
Brake Lamp Light Is On
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
Originally posted by Mrdanbkidd View PostCongrats. Keep us posted and try and maybe get a part number? If it works for you I may need to see if I can find the part for mine.Last edited by SilverShadow; 09-12-2013, 09:49 PM.
Originally posted by SilverShadow View PostI can't get the photo's to come up...Too big ...So I'm going to try to put it on my site www.accordobsession.com. (I think you have to register to see posts...sorry) and it took a sec to put in and YES IT IS THE FIX!
I thought I got the pictures up here of the part I got to fix the problem? Either I was deleted or it didn't stick. (if it was deleted..just pm me and say it was...no need to say so here and embarrass me) Oh well it will be a hassle to do it all over...You care to see...PM me.
And yes..the problem is gone.
Originally posted by Qiko View PostNice, so only need one part?
wow, that part number, 46505-SA5-000, brings up a lot of hits on google too.
Awesome find, definitely going to try this
yes! the part is the size of a button..but did the fix. Guess I will be nice and try the pictures on here once more...
~ALL BEHIND THE BREAK PEDAL ~
The part number
[COLOR="RED"]The part[/COLOR
What it looks like Before fix
The Fix!
Notice the location of White part:
Hope this was useful to someone...can't imagine it being a common problem with the way our cars are built. Does that white part wear away? From the blue dots on my photos...I'm guessing the previous owner messed with it and forgot to reinstall the part. How the heck the light never showed being on all that time, I don't know. Also a few years back I did the first tune-up after buying it...about 300 miles after....Pulled the plugs and some had no bottoms! So moral is ...check that pedal for the white grommet..and pull a plug when buying a used car? LOL!Last edited by SilverShadow; 09-17-2013, 08:14 AM.
Will have to check this out on one of my cars as the brake light lamp is on, and has been on for months. All of the lights are functional and I've replaced all the bulbs. I had this switch go out on my other Honda, but it caused the brake lights to stay on, thus running down the battery. The cruise also didn't work until that part was replaced. I assumed if that part was bad, all of the above would happen. I'll definitely check that before taking apart the dash and seeing if there's anything wrong in there.
I had the same problem, recently. The only way i figured it out was after i replaced the brake switch I still had the problem, and I just so happened to find the rubber piece while i was in there changing the switch out. I put the rubber piece back in and problem solved. My cruise control also didnt work, and after looking at everything but the clutch switch (just like the brake switch but on the clutch) i checked it out and the rubber piece was missing from it too. So i found a piece of plastic that fit the hole and now I have cruise control again lol
Originally posted by SEgirl View PostWill have to check this out on one of my cars as the brake light lamp is on, and has been on for months. All of the lights are functional and I've replaced all the bulbs. I had this switch go out on my other Honda, but it caused the brake lights to stay on, thus running down the battery. The cruise also didn't work until that part was replaced. I assumed if that part was bad, all of the above would happen. I'll definitely check that before taking apart the dash and seeing if there's anything wrong in there.
Look again at my post for the part and where it goes. Let me/ us know you solved the problem.
If you have a wagon go in the trunk and pull that right side holder/cubby hole cover, take your junk out and pull the inside plastic jug thing out too, there's a weird connection back there coming from the lights... My wire was badly connected in the middle someplace making the light indicator come in once in a while when all bulbs were fine and then made a whole taillight go out after accidentally tugging on it but I immediately knew what it was soooo I squeezed em together and wrapped em with tape tightly bringing my light back for a while til I redid the connections later.
When I first got my wagon the left taillight wouldn't work with a new bulb so I traced the wire back up to the driver door sill with a tester where there was still power and ran a fresh wire.4000watts just so all the haters hear me comin!
All good and dandy. I believe what the problem the OP had was not that they didn't come on...but rather they didn't go off. Surprised that you say your light failure was traced to a wire problem. Honda's are well made and in all the years I have read here, I have not heard of a factory faulty wire, and in a wagon like I have. I suspect that somehow that wire was messed with over the 20+ years of ownership. Someone ran maybe a speaker wire or ? Seeing how it was traced to the sill by the driver, it could have worn from being stepped on constantly. Like I posted a picture on the fix, you might do a DIY on how to use a tester to find the problem like you did. I certainly don't know how to do that, and would love to see.
Good job solving the problem guys! I actually had this happen to me awhile back and figured it was the switch near the break pedal. I just ghetto rigged it and put a bolt/screw in the place of the part that broke off. I guess after stomping on the pedal so much, it's bound to break eventually.
Originally posted by Grahf View PostGood job solving the problem guys! I actually had this happen to me awhile back and figured it was the switch near the break pedal. I just ghetto rigged it and put a bolt/screw in the place of the part that broke off. I guess after stomping on the pedal so much, it's bound to break eventually.
