Whats the best performance oil for the city?
    Originally posted by andrew22888 View Post
    I use to work at a place doing about 50 oil changes a day. And trust me if you want to gunk up your engine use some pennzoil. If you want to use something that is gonna perform good and pe reasonable priced use mobile one or valvoline. If you want something that is gonna last awhile without having to be changed and also is good use amsoil. If you want something that works awesome like amsoil but doesn't last as long use royal purple.
    Here's some evidence to my previous post. Guy had an oil analysis done on his TSX. 5500+ miles of stop and go traffic in Boston according to the owner.
    http://www.tsxclub.com/forums/1st-ge...oil-ultra.html
    Pepboys also has a special on 5qts of the Pennzoil Ultra oil and Purolator Synthetic 10k mile oil filter for 40 bucks
    http://www.pepboys.com/sale_specials..._oil_sep13_cp/
    member's ride thread
    91 Accord SE 176k
      It's not against the rules... you're just not able to post outside of this section yet. I don't see why this would be a regional-specific question anyway....
      At first I was going to close/delete as we try to stay away from these "What should I do?" threads. Especially when it turns into the "Paraffin Wax War". Oh dang I just said it! There goes the neighborhood.....
      I used to run Royal Purple, AMSOIL, etc for years. The only performance it changed was that of my monthly budget. Now I use "lowly" Castrol. Now that I work for a Dealership that sells diesel vehicles the techs occasionally give me a "magical potion" of diesel oils and conventional ones that they put in the Porsches(if a 911 will run off of it, then I'm sure my Honda will be fine). They won't tell me what it is, but that stuff works! But don't let that confuse you.
      '94 JDM H22A: 178whp 146wtq
      If you say double dutch rudder, i'm banning you...
        i always use castoral gtx 10w-30 or valvoline with a stp oil filter, change every 3,000 miles
