Bumper, hood, fenders, and trunk lid crooked! Help?
    Alright so my front bumper was taken off a few months ago before I bought it and the guy said he lost the black grooves that slide onto the white screw on the fenders to lift the bumper on the sides, and there's only a few push in pins holding the bumper on. Does anyone know where I can buy this? I don't know what they're called, but without them my bumper is horribly crooked as well as the fenders. The trunk leaks so I have it parked under the shed until that's fixed. Any advice?/:
    JDM powered CB7
    Go buy them from Honda, they are not expesive. As for the trunk you'll need to find the leak. Search on here for the best things to look for when having a trunk leak.
      For the trunk leqk, check your tail light gaskets.
      92 Honda Accord LX - Sold
      2005 Nissan Altima 2.5S - Sold
      2007 Dodge Charger SXT
        For the trunk leak, check all the damn seals lol, I had the same problem. For the tail light seals use a rubber mouse pad and cut out the appropriate shape and replace the nasty old one. The trunks weather stripping is also fairly easy to work with.
        For the bumper and fender, try those ebay quick release things lol. Know a guy who bought them and they seem to be working good
          They're still available OEM? I have two extra sets right now, but am not in a position to sell right now
            If they're not still available at Honda, there are plenty in the junkyards.
            Cross-reference Honda part numbers with other models. You may find that the same parts are used on newer Accords, Civics, Integras, etc...
              Can also check Majestic Honda.
              http://www.hondaautomotiveparts.com/...catdisplay.jsp
              Project:Black Skittle
              AOM->April 2014
              MRT->http://www.cb7tuner.com/vbb/showthread.php?t=199779
                trunk leak is most probably your tailight gasket, its a common issue,
                most people will tell you to fabricate your own or to use silicon...listen..the part is like 20$ at Honda..so fix it right and just get a new gasket...
                for the bumper brackets...junkyard..
                MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201008
                  Sorry for the late update, I've been busy with this h swap, but I've went and bought a new trunk lid with the flush wing ill most likely buy the new gasket for the trunk within the next day, I'm in SC so not many cb7's are seen around here. :/
                  JDM powered CB7
                    trunk gasket? why? if yours is not ripped, you dont need to change it, like said worst case hammer the lip on wich it sit a bit upwards and thats it
                    buy new taillight gaskets instead, those dry out and leak in the trunk.
                      For the trunk leak: Also check out the 8 anchors for the rear window chrome trim. Each of them has a small seal similar to the tail lights. If the tail light gaskets are bad, they most likely are too. Some weather gasket sealer works great on them. The DPO of my Accord tried to use double sided tape... it did not work and I had a bad case of Waterfall fed Lake Honda (it might have worked had they removed the backing tape from the tops).
