Crack in both front brake pads
    During a wheel change today I noticed that both outer brake pads on the front have a small hairline crack on the leading edge. Both sides are almost identical.
    Question is: Is this safe to drive on? The pads still have a lot of life left (Centric Stoptech ceramics).
    1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
    Stock F22A6
    VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
    H23A1 powered
    NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
    CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
    It's probably not safe. Usually when this happens, it's a master cylinder issue causing too much force on the pad - cracking it. If you have a lifetime warranty on those, I'd go change them out soon. Better to be safe, man. If it's brakes or suspension, and you question it, repair it.
      I tend to agree, unfortunately the warranty on Centric is only 90 days. Maybe I should try Powerstop instead.
      If anything the pressure on the pad should be lower than stock since I have a stock master cylinder and wagon brakes.
      Stock F22A6
      H23A1 powered
