91 accord ex question
    I was thinking about my 1991 accord ex recently. The owner who had I previouly told me that he replaced the engine with another used one. What did 91 accord ex's come with stock? I currently have a F22a4.. Is that stock or..?
    Your 91 EX had an F22A4 from the factory.
      Is there a way I can tell? I had no physical proof
        open up the hood and look at the block its stamped on the left side if your looking at it from the front.
        C-3PO's MRT USDM yo!
          Are you talking about that sticker that's on the fire wall on the left(passenger side) if you're standing from the front?
            There is a stamping on the engine itself. There is a flat area just below the distributor, near where the engine bolts to the transmission.
            If your engine's dirty, it may be hard to read. Most Honda 4-cylinder engines will have the engine ID stamped there.
            Sorry, I don't have pictures to make it clearer.
            *EDIT*
            Found this after a quick Google search:
            Came from here:
            http://asia.vtec.net/topics/enginecode.html
              If you are certain your car is a 91 EX, it def. came w/ an A4 motor.
              http://www.cb7tuner.com/vbb/showthread.php?t=39834
              If you look @ post #9, it doesn't have the trim levels on it but I know this has been posted many other times on here. All CB DX/LX rec'd F22A1's, 90/91 EX rec'd F22A4's, 91 SE/92/93 EX rec'd F22A6's. That sums it up for what car got what engine.
                Unless you're from canada, then your ex is basically a US LX and has an f22a1
