Old 04-14-2018, 03:22 PM   #21
Losiracer2
CB7tuner Member
Losiracer2 seems to have made some friends!
Send a message via AIM to Losiracer2
you can rent the vacuum pumps at autozone. I've still got R12 on my 93 EX coupe since it uses the Hadsys style compressor which was very difficult to find. Replaced mine back in 2013 when the car had about 225k on the chassis.
A can of R12 is about 25 on craigslist, so its still accessible. I'd keep running it. Once its fixed properly, it'll last another 5-7 years with a new compressor. Nothing should leak out in that time anyways.
__________________
member's ride thread
99' Lexus LS400 155k VVTi V8 gets up & goes...new DD
91 Accord SE 176k
97' Honda Odyssey 196k miles...$485 spare van for my parents
Losiracer2 is offline   Reply With Quote
Old 04-16-2018, 07:59 AM   #22
zedjr10
Gold Member
zedjr10 may have said something they shouldn't have...
It has already been converted for r134a. I know r12 is a bit colder but don't want to muddy the waters.
zedjr10 is offline   Reply With Quote
Old 06-29-2020, 04:54 PM   #23
wtfisafleek
CB7tuner Member
Quote:
Originally Posted by fleetw00d View Post
I just cost me $142 for an evacuate and recharge (with about 45 minutes in between so I could go home and replace the pressure switch). I believe it is technically illegal to deliberately release the Freon to the atmosphere, so the system should be evacuated prior to changing the compressor (unless it has all leaked out already).
Hey Fleetwood, you mentioned replacing the pressure switch. Can this be done without releasing pressure from the system? Also, the tech that filled my system said that it needs an R-134A specific pressure switch, but I don't see any advertised that way. Which one did you use?
__________________
My '91 LX build. Bought September 2017. Sold June 2020.
http://www.cb7tuner.com/vbb/showthre...r /> t=209871
Old 06-29-2020, 07:38 PM   #24
fleetw00d
Contributing Member
Pressure has to be released to replace the switch (if you don't, you'll release the pressure and lose the Freon when you remove the switch). I believe I used a used OEM Honda switch that I had in my parts collection.
fleetw00d is online now   Reply With Quote
Old 07-02-2020, 08:48 AM   #25
wtfisafleek
CB7tuner Member
Ok that's what I figured. Ty for the info.
__________________
