i just became a member today and i was wondering wat that problem could be.....nebody have an answer????...everytime i put my car in park or neutral my engine revs on its own.....how do i fix that????
idle on my accord revs on its own when on park or neutral???
i also had erratic idle, but the valve didnt help. It ended up in the end to be that my alternator belt was too tightWife: "Why do you get G power platinum and i only get V power?"
Me:"Cause i have the high compression 93 octane only H22 and you have the bullet proof F22."
Wife:........................"But yours are prettier"
Wife:Baby, not everybody wants to do the 93 conversion"
Me:YES THEY DO, THEY JUST DON'T KNOW IT YET.
If it stops when the coolant comes up to temperature, it is very likely the fast idle valve needs to be adjusted. Mine used to do this. I replaced the IAC and it didn't fix it.1992 Accord EX 4dr 5spd - SOLD after just over a decade of ownership
2000 Subaru Legacy GT wagon 5spd
AHM Platinum Parts Counterperson
the cars are equpt with a fast idle.. when ur turn ur car on and ur engine is not up to temp, it'll rev up 1500 rpm+ higher and higher til about like 1800-1900ish and then slowly work its way down and thats like a warm up feature.. but if it just jumps randomly, adjust ur fast idle vavle, but sometimes if u just turn ur car on and shift to R or D and u drive a lil brake, put it into N or P it'll jump back up because its still not warm enough...
You need to provide more information. Exactly what type of Accord do you have. What year, what trim (DX, LX, EX or SE), what type of tranny, mileage. Any other details to the problem? Did this happen after some recent work was done? If so, what was done, etc. What has been done to fix the problem thus far and if any components have been replaced?
