what do u think about this setup?? f22b turbo
    hi all,
    i just swapped an jdm f22b to my accord and im thinking of boost.
    i had an h22 turbo before this swap,
    and i want to use the same parts and setup now except the manifold
    2.5" ic pipes
    gt3271 devided t3 flange
    log manifold
    this is for stock internal
    will this be laggy ??
    what size intercooler are you going to run?
      this is it: 28" X9" X 3" WITH 2.5' INCH INLET/OUTLET
        any one??
          i also purchased a dohc f22b and am planning to go boost. btw, how much power are you looking for out of this setup?
            Originally posted by f22bt View Post
            hi all,
            2.5" ic pipes
            log manifold
            to answer your question, no it will not be "laggy".
            either AR.69 or AR.78
            should be a nice setup,you will definitely see some decent numbers with it.
            good luck
              i agree it sounds like a nice setup keep us posted on the progress
                i'm looking for +230whp for a daily use car, and a/c on.
                  thanks guys for the replies,
                  i post some pic when i start the work
                  btw, its sohc non vtec.
                  how much can i rev ? on what rpm do think i'll hit the 6 psi ?
                  also, i'm using 780cc precition from my blown h22a, is that ok or i need smaller inj?
                    What are you using to tune, not that it matters too much I'm just curious...don't forget to make a MR thread so you can keep us updated on the progress...love seeing f22's boosted
                    ____
                      go for it
                        your injectors are good,get a FPR.
                        are you doing anything to the head?
                          no, i won't.
                          actully when i installed the FPR today, i saw some thing like a filter inside the return port in the fuel rail?? is it a filter?? or i'm just rong.
