Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 12-26-2010, 02:32 AM   #61
mndude07
mndude07 seems to have made some friends!
Send a message via AIM to mndude07
Originally Posted by 91_CB7_Sedan View Post
I'll be sure and send them an e-mail on Monday to ask about their group buys, and spring rates/damping info for you
Some things to ask:
Inline separating piston?
Steel piston? O-ring sealed?
Deflected disk?
Have any low speed sticktion?
Damper adjustment linearity?
What brand are springs? What's the tolerance? What rates for the CB7?
What aluminum do they use? 6061 t6?
What type/brand of bearing do they use in the top mounts?
Percentage critical damping? Digression knee at what velocity?
If they won't tell you some of that, its not a big deal, but a good company shouldn't have anything to hide like that.
There are no black and white suspension answers!!!!!!!!!!!
mndude07 is offline   Reply With Quote
Old 12-26-2010, 02:53 AM   #62
91_CB7_Sedan
91_CB7_Sedan is cool... so far.
Send a message via AIM to 91_CB7_Sedan
Originally Posted by mndude07 View Post
Some things to ask:
Deflected disk?
As far as the rates are concerned, If you watched the video on their site, it says that the coilovers are made user specific, so if I want say 10K front, and 8K rear spring rates with my coilovers, then they can do that for me. Their Racing Spec coilovers are also offered for the cb and cd chassis.
Originally Posted by Makaveli2k View Post
White girls make the world go round. If I were to be stranded on an island and I could only 3 things to bring with me It'd be 2 different white girls. And a Smashing pumpkins Cd... I hear they like that shit. =p
91_CB7_Sedan is offline   Reply With Quote
Old 02-08-2011, 07:06 PM   #63
EJX_Michael
EJX_Michael is cool... so far.
Send a message via AIM to EJX_Michael
Did you ever get anything back from them?
EJX_Michael is offline   Reply With Quote
Old 02-10-2011, 07:23 PM   #64
19dabeast85
19dabeast85 is cool... so far.
Are the damping numbers for the koni struts correct? The str.t just seems way too high.
Also, can anyone verify if the height notches on the koni/neuspeed yellows (sports not sp3) allow a height RAISE or only the 15mm of lowering which is all I can find proof for??? I NEED to know for sure or I won't buy them.
My Member's Ride Thread
19dabeast85 is offline   Reply With Quote
Old 02-14-2011, 06:09 PM   #65
marcusv8thunder
marcusv8thunder is cool... so far.
liking this thread muchly!
UKDM 93 CB3 Page (1) H22A U2Q7 LSD
UKDM 91 4ws Page (3) OEM Minter
NOW H22A U2Q7 SWAPPED
marcusv8thunder is offline   Reply With Quote
Old 04-06-2011, 07:50 PM   #66
92accordcb7ex
92accordcb7ex is cool... so far.
bump for this thread . does anyone have any good pictures of koni str.t's and neuspeed sports? i have mine on order and should be getting them next week i just want to know of about how much of a gap well be there after they settle? i know before they do itll be about 2 1/2 finger gap in the front and about the same in the back.
92accordcb7ex is offline   Reply With Quote
Old 04-27-2011, 08:06 PM   #67
marcusv8thunder
Also im 80% sure the stock rates are 220F and 150R
so stick that on the first page if the rates can be confirmed by someone.
Old 04-27-2011, 08:19 PM   #68
mndude07
Where did you find that info or what leads you to believe that?
Old 04-28-2011, 09:15 AM   #69
gloryaccordy
I did measurements and my calcs/readings came up pretty close to that. Rear was fuzzy cause of the dead coils, but yea, stock spring rates are def. that low
Old 04-28-2011, 07:39 PM   #70
mndude07
I have no problem believing the stock rates are that low. I'm honestly surprised the front is as high as it is. I would just like some accurate measurement and/or hard numbers to prove it. Who knows what these ~20 year old spring's have degraded to over time either. They likely had a different rate when they were new. Also, if stock is 220F and 150R, that means the Tein H-tech springs are identical to stock springs, just that they lower the car some.
Old 04-29-2011, 08:09 AM   #71
marcusv8thunder
Those figures are from a guy that works for Honda in the UK, from another Accord forum.
He found out the stock spring rates ,for all the generations from 8 down to 5. I then asked him to check the 4th gen for me lol, and posted up those rates.
I like to think his source is solid, but if it can be confirmed with calculations obviously that would be preferred.
As for the lowering springs that are just as soft but lower, they should be used with uprated dampers, and progressive bumpstops to be maximised, IMO anyway.
Old 04-29-2011, 11:58 AM   #72
mndude07
Okay, I added those rates in the original post as the stock rates. If a member on this specific site is able to measure and get a different value, we'll go from there. Otherwise, we'll assume 220F, 150R.
I just have a tough time believing it because that means that Neuspeed sport springs are only about 20 lbs stiffer, which is hardly noticeable....and sport springs are quite noticeably stiffer than stock...and the fact that they're progressive should make them feel even softer than they really are, yet they still feel significantly stiffer.
Again, I haven't been able to measure a stock spring yet, but just based on that logic, 220F, 150R seems too high. However, I just put that rate on the original post for the time being since its the best thing we have so far.
Old 04-29-2011, 02:36 PM   #73
marcusv8thunder
Yes thats fair enough.
Theres lots of variables to consider with bump stops and ride hieght and newness of the lowering spring would give the feel of stiffer ride.
Especially if your comparing to a 20 year old spring like you said earlier.
Oh and you put 250F instead of 220F on first page
Old 04-29-2011, 05:51 PM   #74
mndude07
fixed
Old 05-15-2011, 11:23 AM   #75
mndude07
Added BC coilovers
Old 06-10-2011, 10:03 PM   #76
mndude07
Added spring rates for D2 Racing lowering springs, thanks to 92 OEM.
Old 07-20-2011, 09:33 PM   #77
KB7
KB7 is cool... so far.
Send a message via Yahoo to KB7
Originally Posted by JoshM View Post
D2 Racing Lowering springs: 2.5"F/2.25"R
the D2 site lists them at 2.25front , and 2.25 rear.
on ebay, (link will not last forever), I saw them listed at 2.5 front and 2.25 rear.
_
KB7 is offline   Reply With Quote
Old 07-20-2011, 09:50 PM   #78
93blackcb7
93blackcb7 may have said something they shouldn't have...
function form type one's
93blackcb7 is offline   Reply With Quote
Old 09-16-2011, 11:06 PM   #79
islandhopper
islandhopper seems to have made some friends! islandhopper seems to have made some friends!
Megan Racing EZ-Street Series
SPRING RATES:
F: 62mm ID; 180mm length; 12 kg/mm
R: 62mm ID; 200mm length; 5 kg/mm
DAMPER SPECS:
F: 95mm stroke; 200mm length; A2 valving code
R: 115mm stroke; 200mm length; A1 valving code
- 15 Levels of Adjustable Damper Strength
- Adjustable Ride Height
- Single-Cylinder Design
Average Force vs. Velocity Graphs
http://www.meganracing.com/uploadima...34_5766_A1.JPG
http://www.meganracing.com/uploadima...13_3055_A2.JPG
Form.Follows.Function
islandhopper is offline   Reply With Quote
Old 02-05-2012, 08:59 PM   #80
SOHC-FTW
SOHC-FTW seems to have made some friends!
Instead of making a new thread on the link i'm about to post i figured it suited this thread the best. Thought it was a good read and has some decent info on it to boot.
http://farnorthracing.com/autocross_secrets18.html
02 Crv
SOHC-FTW is offline   Reply With Quote
