I am putting on the f22a6 intake manifold runners on my a4. Because they are dual runners and the iab valves open at a different rpm will I need a tuning for them to function properly?
Will I have to retune after getting new Iab valves???
For sure. If you are changing the mix of A/F due to larger intakes or exhausts a tune is required. This is assuming you have something to tune (proper ECU). This also implies someone already made a custom tune for the old setup.
Otherwise if it's all OEM (ECU, etc.) then no. Let the ECU sort out the A/F for open loop (driving). Idle may be a bit weird in open loop.
Originally posted by Raf99 View PostFor sure. If you are changing the mix of A/F due to larger intakes or exhausts a tune is required. This is assuming you have something to tune (proper ECU). This also implies someone already made a custom tune for the old setup.
