Most Powerful Naturally Aspirated CB7 List
This is a sticky topic.
    Originally posted by 98vtec View Post
    years and years down the road and no one has come close to scott?
    Funniest thing is I don't think his build is even mentioned in this thread.... But I didn't read all the pages to check. I do know that his user name, 2point6, isn't listed in the 2nd post labeled "King of the N/A CB7s" though.
    Not sure if there are any guys here with the bank roll or shop supplies that he had ether. That being said he definitely pushed this platform to it's limits. I'm sure if Ndubisi Ezerioha's F series build was included here it would be hard to touch as well.
    I think the hybrid boys are doing well to hit 240/250 N/A on a budget 1/4 of what Scott would have spent on his build.
    Most of the guys around here are hobbyists and weekend enthusiasts. Not as many game changers and all out race engine builders around as there used to be.
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
      i just figured there would be at least one.
      i know i have settled down big time
      www.850fab.com
      IG - @850Fab
      FB - @850Fabrication
        jdm92_accorn seems to be the resident R&D, trial and error, hybrid guy around these parts now.
        Unless you do this for a living it's hard to keep pushing for more without having the bank roll. I don't think many of the innovative DIY guys that are still pushing these platforms stick around these forums as much. IMO that is due to the increased amount of trolls and spoon feeders. The kind who want all of your time, information and research for nothing.
        MR Thread
          well i am proud of the 280whp i got out of my prelude chassis but the races i went to always had a small all motor class so i bailed. didnt help that the intake cam broke and found a whole mess of stuff wrong from the engine builder but oh well.
          prelude is on the bottom of my list of priorities for many years to come.
          www.850fab.com
          IG - @850Fab
            That sucks.... I have a hard time sending stuff out to local engine shops. 90% of the builds they do are domestic V8's. Not sure if they even own a precision measuring tool, pretty sure plastigauge is the measuring tool of choice for most.
            My Accord build is also on the bottom of my priorities list. I have all of the parts and she's in a warm dry spot. I will get back to her at some point in time. Maybe I'll have my own machine shop by that time.
            MR Thread
              DonF built the bottom end. Unfortunately he built my engine at a time where he really didnt give a shit what would happen to it given he knew his time was limited.
              I fell in love with boost though so its going to take a lot for me to build another NA engine.
              www.850fab.com
              IG - @850Fab
                the whole thing about n/a is the love of the n/a engine and the science behind it. im starting to change my mind about the whole boost thing now. i plan to dip into boost at some point on my 93 coupe. my black one will stay n/a though. blake, i cant wait to see the PH2B kit in your car. i think i might check that out for the black coupe. that is probably the hardest thing about the n/a cars is proper gearing.
                MRT: http://www.cb7tuner.com/vbb/showthread.php?t=95154
                  The majority of this banter should be deleted, but since it comes from veteran members I'll allow it on the basis that it is closely related and should answer some noob's (Or my own. ) question in the coming months.
                  But to answer your questions Scott is pretty much out of the scene(He really is, save some special people). To be "fair" he would have to post his old setup. Bisi's setup was never documented on the forum to my knowledge and such wouldn't qualify. They are more than welcome to do so should they ever decide to.
                  This thread is more for the current "movers and shakers" in the N/A arena in regards to the chassis. As builds come and go, they will be logged for quick reference.
                  '94 JDM H22A: 178whp 146wtq
                    K&N filter
                    BLOX 4" velocity stack
                    AEM BB6 V2 SRI
                    Skunk2 Alpha series 70mm TB
                    Skunk2 Pro series V2 H22 intake manifold
                    OEM RDX 410cc injectors
                    AEM adjustable FPR set at 45psi
                    balance shaft belt removed
                    PT6 (F22A) full ported and polished cylinder head milled .060" (bumps compression to 10.9:1)
                    Web Camshafts custom hardweld .440"/.425" 238*/250*
                    Bisimoto Pro valve springs
                    Bisimoto billet aluminum rocker spacers
                    Bisimoto cam gear
                    NGK blue wires
                    OEM Honda new Cap and Rotor button
                    JDM F23A short block
                    Bisimoto V2 4-1 header
                    3" exhaust turn down
                    M2S4 trans
                    E85 fuel[/QUOTE]
                      Updated.
                      You've made it, now sit your ass down!!!!
                        im done for now.
                          Flirting with piston speed problems at those rpm's on that stroke length. Nice numbers though. Interesting that an additional 1000 rpm's basically only equated to 25hp. I figured you would've seen a bit better return for that. How well does the hardweld idle?
                          Originally posted by wed3k
                            If he could maintain his torque he would see better numbers...still for a single cam with no variable lift it's very impressive. I wonder how much an H could put out with that amount of work.
                            YouTube Clicky!!
                              an h with the same work is posted, pretty similar numbers. i'll be back later on with another build using 11+:1 and a much more aggressive cam. the hardweld idled decent if idle was set at 1200rpm. it's just laggy until about 4k.
                                any videos? very impressive SOHC
                                -1993 Accord EX SOLD
                                -2012 GMC Canyon V8 4x4
