cb7 whip project
Should have grabbed the rear center cross member and sway bar while you were at it. The LX cross member doesn't have mounting provisions for the sway bar.
Edit: Noticed it is a 91 EX, so I guess it probably already has the rear sway bar.
Anyway - welcome. A fresh set of plugs, cap, rotor, air filter, and set correct timing (make sure you don't have a lot of oil in the spark plug holes) might go a long way to improve your gas mileage.Last edited by Fleetw00d; 11-06-2015, 12:52 AM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by kapone View Post^did you mean 290 miles to a tank of gas? if so that's good but it could be better. I get 380 on winter blend and about 410 on summer blend...
Vehicle looks good... BTW I have 280k on the motor if you take care of it they last....
Originally posted by fleetw00d View PostShould have grabbed the rear center cross member and sway bar while you were at it. The LX cross member doesn't have mounting provisions for the sway bar.
Anyway - welcome. A fresh set of plugs, cap, rotor, air filter, and set correct timing (make sure you don't have a lot of oil in the spark plug holes) might go a long way to improve your gas mileage.I'm faster then a prius
Originally posted by oni_cb7 View PostAccelerate slow and keep rpms around 3k. Plus, lots of freeway driving. You can easily get 400.
5 Lug Swap looks sick
Originally posted by GTRON View PostWhat happens if you have oil in your spark plug holes?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
