Old 04-26-2017, 01:58 PM   #21
G. Wiffington
CB7tuner Member
G. Wiffington seems to have made some friends! G. Wiffington seems to have made some friends!
Quote:
Originally Posted by GTRON View Post
I have an eBay exhuast, with a magnaflow high-flow cat, and muffler, and I had rasp. Welding on a long red glass pack got rid of the rasp, and made the exhaust sound warmer.
If I were to do it again I would buy a OBX header, and a Yonaka exhaust.
I have the Yonaka cat back system & I love it. Nice, deep/low rumble.
G. Wiffington is offline   Reply With Quote
Old 04-26-2017, 02:29 PM   #22
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
Just saying... Yonaka and OBX are "eBay" companies. Just knockoff reproduction companies that frequently produce inconsistent products. They seem to be two of the better options, and I'd probably consider either one for exhaust components, but they're not high quality companies. One person's good experience may not translate to you having one that is similar. Inconsistency is very common among those brands. If you want consistent performance (and by "performance", I also mean sound, fit, and reliability), pay for a quality brand.
Supporting quality brands is also a way to ensure they continue supporting our incredibly old and fairly unpopular platform.
__________________
deevergote is offline   Reply With Quote
Old 04-26-2017, 03:24 PM   #23
G. Wiffington
CB7tuner Member
Yeah I hear you. We'll see down the road with how long it will last. I think I installed it last summer. I know I did have a problem with fitment when I first installed it. It seemed to be too close to the undercarriage causing the exhaust to hit the rear sway bar & making a loud vibrating noise. I just used longer exhaust hangers to compensate the distance between. Now there is no problem. My CB is not show room quality & I do not drive it everyday (more like every 2 weeks at this point in my busy life) so that is why I chose a "cheaper" route.
Old 04-26-2017, 03:27 PM   #24
deevergote
Don't call me dude.
It's not a terrible option. I just want to mention the inconsistency thing so people know your good experience may not mean they'll have one as well.
When it comes to exhaust stuff, the cheaper stuff is often passable. We're very quickly losing legitimate aftermarket support, but that may or may not be associated with the support of cheap knockoff companies.
__________________
Old 04-26-2017, 03:34 PM   #25
G. Wiffington
CB7tuner Member
Yeah I would feel bad if I had a good experience then someone went the same route & absolutely hated it.
Speaking of bad products, when I installed my new Koni setup I decided to redo the inner & outer tie rods. I ended up getting a bad Moog outer (brand new, right out of the box). It had a lot of play like it was already used.
So I guess there is always some sort of inconsistency with parts sometimes?
Old 04-26-2017, 03:38 PM   #26
deevergote
Don't call me dude.
Moog's quality has declined sharply in the last few years. I had a rear upper ball joint boot fail on me in under 3 months, and I never once drove the car after installing it (complete with the new arm... not just the boot or the joint)! I avoid Moog now as well. I'm honestly not sure what good OEM alternatives there are for many more mundane parts (like ball joints and tie rod ends). For the longest time, Moog was the standard. If you didn't want to pay OEM prices, you got Moog. Now, it's OEM or crap, it seems.
__________________
Old 04-26-2017, 03:44 PM   #27
G. Wiffington
CB7tuner Member
Damn! what a shame..Yeah I know, Moog was always the talked about brand for suspension components.
Old 04-26-2017, 03:59 PM   #28
Rilas
Gold Member
I stick with AC Delco and Beck/Arnley honestly for tie rods. That is when I can't afford OEM. Which happened this last time. I bought AC Delco for all of it. It all came with a lifetime warranty and the outer tie rods are Senkei 555, which is OEM for our cars. I'm not sure who made the inner tie rods but still, way ahead of where Moog is at.
Outer Tie Rod
Inner Tie Rod
Sorry to sort of derail the thread. But hey you guys started the derailing before I showed up!
__________________
Old 04-26-2017, 05:43 PM   #29
deevergote
Don't call me dude.
It's pretty much done as far as the initial topic goes, I think! AC Delco is oem for GM, so yeah, they're probably quite good.
__________________
Old 04-26-2017, 05:59 PM   #30
Crankshaft
CB7tuner Member
Crankshaft is cool... so far.
Send a message via Yahoo to Crankshaft
Quite alot of ACDelco suspension parts are actually made by Moog, there were theories about this but we're confirmed when both companies put out same parts with the same defects at the exact same time. Honestly though every company has bad batches or quality control issues at one point or another, the difference is that some see the mistake and try to solve it while taking care of the damages caused by the faulty parts while others don't care and keep pumping out crap at the expense of those loyal to the brand.
__________________
Crankshaft is offline   Reply With Quote
Old 04-26-2017, 06:42 PM   #31
deevergote
Don't call me dude.
That's right. I think you had mentioned that before.
Moog's tendency to produce faulty parts more often now seems that their quality control has lessened. That, or they produce lower quality stuff for older, cheaper cars.
__________________
Old 04-26-2017, 07:45 PM   #32
Crankshaft
CB7tuner Member
The question i would ask is; with all the issues that have arose, are there any companies that are actually better than Moog? I know its parent company Federal Mogul also makes some suspension parts, are THEY also having issues? I might be inclined to say that even with the issues Moog might still be the top choice out there. We have to also consider that Moog has two lines of products with one of them being inferior, i am not saying this was the case just a posibility.
__________________
Old 04-26-2017, 09:36 PM   #33
Cragelarson83
CB7tuner Member
Cragelarson83 is cool... so far.
I can change it for you. What exactly do you want the title to be?
As for fuel economy, increasing your engine's ability to breathe will actually DECREASE fuel economy in most cases. Greater airflow in and out of the engine will likely result in a greater oxygen content in your air/fuel mixture. The ECU will see this via the o2 sensor, and send more fuel to compensate. The best way to ensure the best fuel economy is to leave it completely stock, and keep the engine in its best running condition.
You CAN gain fuel economy with a custom ECU tune, but even that can be iffy (especially since the PT3 and PT6 ECUs are tuned quite well already).
2.5" piping is quite large for an F22A that is not going to be pumping out significant horsepower. That will raise your powerband a bit, forcing you to rev higher to use your engine's power. This will also contribute to a decrease in fuel economy.
To be quite honest I just want this thread to help people decide what they want to do. so that being said you have the most experience obviously with this website. I trust your judgement I know that my original title isn't the best for the information in this thread. I'm looking forward to having some more questions for you that I can't find answers to.
Cragelarson83 is offline   Reply With Quote
Old 04-27-2017, 12:30 PM   #34
G. Wiffington
CB7tuner Member
Quote:
Outer Tie Rod
Inner Tie Rod
Honestly, I like the quality of AC Delco from what I have experienced first hand. Beck/Arnely has always been another backup that I would use as well. Advanced Auto always one of the two brands when I need something immediately on the weekends when I don't want to wait a week for a part through the mail. I can't complain on either brands (until I get an inferior part haha)..
Tags
dna header , f22a1 , oem exhaust , raspiness
