Old 08-18-2009, 05:58 PM   #21
buckysaccord93
buckysaccord93 is cool... so far.
Send a message via AIM to buckysaccord93
WOW my german is really rusty good thing you decided to type in some german i havent used it in so long
You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
buckysaccord93 is offline   Reply With Quote
Old 08-18-2009, 06:19 PM   #22
foamypirate
Generous Douchebag
foamypirate seems to have made some friends! foamypirate seems to have made some friends!
Ich mochte ein ananas fur essen. JETZT!
I didn't even have to translate that. It took me 4 years of german class to learn how to say, "I want a pineapple to eat. NOW."
Oh yeah...
Originally Posted by sweet91accord View Post
foamypirate is offline   Reply With Quote
Old 08-18-2009, 10:15 PM   #23
$KAT3R_rc
$KAT3R_rc is cool... so far.
sorry for typing all wrong my bad. while back i cleaned the IACV, so maybe the gasket i dont know.
$KAT3R_rc is offline   Reply With Quote
Old 08-18-2009, 10:33 PM   #24
deevergote
Don't call me dude.
Állítsa be a FITV.
Old 08-18-2009, 10:38 PM   #25
$KAT3R_rc
Fitv?
Old 08-18-2009, 10:43 PM   #26
8ball
8ball seems to have made some friends! 8ball seems to have made some friends!
Does the german have to do with the Ingloruious Basterds movie scripted by quentin torrentino???
8ball is offline   Reply With Quote
Old 08-18-2009, 10:57 PM   #27
deevergote
Don't call me dude.
Originally Posted by $KAT3R_rc View Post
Fitv?
Válvula de ralentí rápido Termo
Es una parte de su cuerpo del acelerador. Debería haber un tornillo de latón que usted puede dar vuelta muy cuidadosamente.
Old 08-18-2009, 11:02 PM   #28
8ball
bwahaha. . .
Old 08-18-2009, 11:03 PM   #29
Bcozzi71
Itazura makaroni
Bcozzi71 is very helpful Bcozzi71 is very helpful Bcozzi71 is very helpful
Send a message via AIM to Bcozzi71 Send a message via Yahoo to Bcozzi71
Ich mag dieses mike! Das macht Spaß.
Bcozzi71 is offline   Reply With Quote
Old 08-18-2009, 11:22 PM   #30
deevergote
Don't call me dude.
Jag besvarar alla frågor korrekt. Bara ... inte på engelska!
Old 08-18-2009, 11:23 PM   #31
$KAT3R_rc
sorry i do not know any german what so ever. even tho i lived in germany for like 4 and half years lol
Old 08-18-2009, 11:36 PM   #32
deevergote
Don't call me dude.
Hindi ko pa sinabi very much sa Aleman. Ako ay gumagamit ng maraming iba't-ibang mga wika.
Old 08-18-2009, 11:43 PM   #33
$KAT3R_rc
umm ok???? please help me what is FITV
Old 08-18-2009, 11:56 PM   #34
$KAT3R_rc
ok look at this i found this at team-integra.net
This is mostly for high and roaming idles but may work for low idles as well.
First, terms:
TB - Throttle Body
IM - Intake Manifold
IACV - Idle Air Control Valve (also called the Electronic Air Control Valve or EACV)
FITV - Fast Idle Thermo Valve
TPS - Throttle Position Sensor
I finally got the swap (b18a) in my civic but unfortunately when I started it up it idled at 3k. Then when it warmed up it had a hunting idle from 2k to 2500 rpm. I stood over that thing for 3 days, testing and scratching my head. On top of that I did a TON of searching on the h-t, hybrid boards, and on G2IC. I hope what is contained within helps someone. Maybe they wont have to go through as much work as I did.
The idle on our Hondas is a tricky thing. It is controlled by two main sensors: the FITV and the IACV. The FITV is a mechanical valve that is controlled by coolant temperature (there is no ECU plug to it). When the coolant is cold the valve is open and letting air into the IM through a hole in the TB before the throttle plate. This essentially creates a small vacuum leak which in turn lets the motor idle higher than normal (supposed to be around 1500-2k for warming up). As the coolant warms up the valve closes and no longer lets air in through the hole in the throttle body. All the while the IACV, which is ECU controlled, is letting small amounts of air into the IM through another hole in the TB. Any amount of extra air the ECU is not expecting will confuse it and you will get either a high idle or a roaming/hunting/fluctuating idle. On to the troubleshooting.
First things first, don't skip any of these steps. From what I have read (and experienced) usually small dumb things cause these problems so don't overlook anything. Also refer back up to the pictures if need be.
1) Check your vacuum routing. On the underside of your hood there should be a vacuum diagram. If there isn't a diagram under there, there is one in a Helms, Chiltons, or Haynes manual for your car (you should have one of these anyway). Remember, ANY extra air will confuse the ECU. Check for cracked or bad vacuum hoses. If in doubt just replace the hose, they are cheap.
The PCV valve could also be the culprit. Take it out and examine it. If it is cracked it could be causing a vacuum leak. Replace the peice if you arent completely sure it is ok (the helms/chiltons/haynes manuals tell you how to check it).
2) Check to see that your throttle plate is closed all the way. Take your intake off at the TB and check to see that nothing is blocking the plate. If nothing is in the way and it isn't closed all the way, loosen your throttle cable.
3) Check to see if the nuts holding the TB and the IM on are tight, this was the source of my idle problem. If they are loose, tighten them.
3.5) Check the Idle screw. Its on the top of the TB right next to the red vacuum line in the first picture. Its a flat-tip screw and most TB's have it epoxied over. If your screw is not epoxied over try adjusting it.
4) Bleed your coolant. Some air bubbles may throw the FITV off and keep the valve open.
5) Take the 3 10mm bolts out of the FITV (you don't have to take off the coolant lines). Then take off the 2 8mm bolts off the plate on the back of the FITV. Once the plate is off you will see a white plastic thing, screw that all the way in. This causes a TON of people's hunting idle problems (it's a source of a vacuum leak). Put the FITV back on and start the car up. If it still idles bad go on. Here is a writeup on the FITV. {Jacksont001 note: it is located below}
6) Clean the IACV screen(s). See Oz's write up on G2IC. {Jacksont001 note: it is located below}
7) Make sure your car is completely warmed up. With it running, take the intake off the TB. There are 2 holes right in front of the throttle plate, these are the holes that feed the IACV (top hole) and the FITV (bottom hole). With your finger, cover up the bottom hole (it should NOT be sucking if your car is warmed up). If the idle goes down the FITV is to blame, either get a new one or take it apart and screw the valve completely closed (I have only read of people doing this, so I don't know exactly how. Also, you will have to keep the engine speed up yourself when the car is cold).
Next cover both holes up with your fingers. The car should sputter and die (or almost die). If it does then the source of your crappy idle is the IACV. Replace it. If you want you can test the IACV. Shut the car off and put + battery voltage to the blk/yel terminal (on the valve) and momentarily touch ground to the blu/yel side. When doing this the valve should click, if it doesn't, replace it.
If, when covering both holes the car still has a high idle, you have a vacuum leak somewhere. Again check the IM and TB nuts. You can spray carb cleaner around those areas and if any gets sucked in (the engine will rev) you have found your leak. Another source of vacuum leaks are where the FITV and IACV connect to the IM. Either replace the gaskets or use silicone gasket sealant.
8) If nothing has worked you should test your TPS. Probe the middle wire on the TPS plug (with the key on but not running, and the plug still connected to the sensor) with the + probe on the volt meter, and the neg probe to ground. You should have .5v with a fully closed throttle plate and 4.8v with it wide open. If the TPS is off, replace it. My TPS was .425v to 4.55v and it idles fine now so I don't know how big the margin of error is. Also, it is pretty rare for these to go bad.
9) If, still, nothing has worked you might want to try a new ECU. This also is very unlikely, but worth a try.
10) If it still idles bad, go through the steps again.
It was a pain to have this mysterious problem and very little info on how to go about troubleshooting it. The idle problem is a real PITA because there are so many things that cause the same result (the hunting idle). When I had this problem I read through a ton of posts over at Honda-tech describing the exact same problem but when I PMed them, they all had different fixes. I hope this covers all of the possibilities. If I skipped over anything PLEASE let me know
Old 08-19-2009, 12:00 AM   #35
BigBlueVan69
BigBlueVan69 is cool... so far.
We are not the ones supposed to be looking. We are the ones that know these things (the ones trying to help.) Have you narrowed it down yet?
BigBlueVan69 is offline   Reply With Quote
Old 08-19-2009, 12:12 AM   #36
deevergote
Don't call me dude.
I've answered all your questions. I even stated what the FITV is, as well as where it is.
Old 08-19-2009, 12:13 AM   #37
deevergote
Don't call me dude.
See? Right there. Explained quite clearly.
Old 08-19-2009, 01:12 AM   #38
Father Time
NW Chat Nazi
Father Time is cool... so far.
Na gawin! Akala ko hindi ikaw ay nagsasalita ng Tagalog kahit na! Ayos.
Sorry, I had to.
3 CB's gone....
1 WK Overland....
Still miss the CB though......maybe one day.
Father Time is offline   Reply With Quote
Old 08-19-2009, 01:21 AM   #39
noobcake
noobcake seems to have made some friends!
aller Sie sind, der dumme stumme weibliche Hunde ist !
noobcake is offline   Reply With Quote
Old 08-19-2009, 01:40 AM   #40
brand0n327
brand0n327 is cool... so far.
haha only a select few on here know german...maybe said clearly in german but i have know idea what he said haha
brand0n327 is offline   Reply With Quote
f22 , h22 , honda accord , turbo , vemon 400
