Old 03-12-2012, 08:40 PM   #1
axel272
axel272 is cool... so far.
Send a message via AIM to axel272
Question f22 a vs f22b1
got a question i blew the motor in my 90 accord f22 a1 knocked a couple holes in the block..needless to say its shot so i came up on a f22b1 wen i was lookin for another motor for 300 buck was just wonderin bout if i should put the a1 head on it with the h23 intake i already had or just swap the motors out i got the wiring and everything else down i think just not sure bout wat the wires are comin from the crank think its pressure switch for the vtec.....if so i was gonna put the h23 mani on the f22b1 just wanted to get a couple of opinions on wat u guys thought on which would be my best bet...and was also wonderin if my header off the a1 would fit the b1 it didnt come with one on it havent got to checkin it yet and i kno i need the p0a ecu for the b1 right?
axel272 is offline   Reply With Quote
Old 03-12-2012, 09:19 PM   #2
Joey GT-R
Super Moderator
Joey GT-R has a HUGE cock! Joey GT-R has a HUGE cock! Joey GT-R has a HUGE cock! Joey GT-R has a HUGE cock!
Send a message via AIM to Joey GT-R Send a message via MSN to Joey GT-R Send a message via Yahoo to Joey GT-R
This is really a matter of opinion. You could go either way. The cylinder ports are identical so your header will fit.
'94 JDM H22A: 178whp 146wtq
Originally Posted by deevergote
Joey GT-R is offline   Reply With Quote
Old 03-12-2012, 09:35 PM   #3
axel272
yeh but ive never messed with a vtec so i dont really know how they run lol
Old 03-12-2012, 09:39 PM   #4
dj_ender
Mod\Dubstep Pusher
The b1's Ports are different from the a1's. The only way he can reuse his header is if he adds the a1 head to the b1 block.
Old 03-12-2012, 09:54 PM   #5
deevergote
Don't call me dude.
Yes. B1 exhaust ports are 0_00_0. F22A, H23A, and F22B DOHC exhaust ports are 0_0_0_0.
You can put the F22A head on the F22B1 block. The blocks are very similar. The F22A head has greater potential when modified, compared to the F22B1... but both are decent motors until you get REALLY serious about a build.
Old 03-12-2012, 09:57 PM   #6
dj_ender
Mod\Dubstep Pusher
I forgot to add that the H23 intake manifold won't fit on the b1's head for the same reason as the header not fitting, different ports as well.
Old 03-12-2012, 10:18 PM   #7
GhostAccord
Keep your F22A head if you want to avoid having to replacing your intake & exhaust manifold. Nether of the ones you have will bolt up.
Another thing to remember if you end up swapping blocks. Remember to remove the oil control orifice from your blown F22A block and screw it into the B1 block. The B1 VTEC block does not have the control orifice becuase the B1 head requires more oil to engage the VTEC assembly.
MR Thread
GhostAccord 2.4L Blog
by Chappy, on Flickr
Old 03-12-2012, 10:19 PM   #8
deevergote
Don't call me dude.
What is the function of that part on the F22A block? Is it just a plug?
Old 03-12-2012, 10:19 PM   #9
dj_ender
Mod\Dubstep Pusher
Another thing to remember if you end up swapping blocks. Remember to remove the oil control orifice from your blown F22A block and put it into the B1 block. The B1 VTEC block does not use the control orifice becuase the B1 head requires more oil to engage the VTEC assembly.
Thanks for that bit of info. Im working on a CD5 right now and when I popped the head off I noticed that plug was missing and was curious about it.
Old 03-12-2012, 10:20 PM   #10
dj_ender
Mod\Dubstep Pusher
I believe it's just an oil restrictor.
Old 03-12-2012, 10:23 PM   #11
GhostAccord
Not exactly a plug. It controls, or restricts, the amount of oil entering the cylinder head.
MR Thread
Old 03-12-2012, 10:28 PM   #12
deevergote
Don't call me dude.
Interesting. I always knew about that oil orifice, but I never knew the details. Mainly because I've never had any interest in a head swap, which is where it usually becomes a point of concern.
Old 03-12-2012, 11:38 PM   #13
Joey GT-R
Super Moderator
Guess you learn something new everyday....wonder why they did that. When you look at headers online they always advertise F22/H23, but I've never seen them say "except F22B1". So I guess it's safe to say H22 headers, manifolds fit then?
Old 03-12-2012, 11:41 PM   #14
'93CB7Ex
Negative. H22 is different.
Old 03-13-2012, 12:26 AM   #15
Joey GT-R
Super Moderator
Well if I remember correctly H22s are 0-00-0...... I know they aren't 0-0-0-0 like F22As.
Old 03-13-2012, 12:42 AM   #16
GhostAccord
Actually the H22's have a 0-0-0-0 exhaust port layout, IIRC the difference is that they have a different bolt pattern than the F22/H23.
It's the F22B1,2 & 5 and F23A1, 4 & 5 that have the 0-00-0 exhaust port design....
MR Thread
Old 03-13-2012, 01:09 AM   #17
Joey GT-R
Super Moderator
Oh well then, I don't concern myself with such things, that header's not coming off anytime soon.....
Old 03-24-2012, 02:44 AM   #18
axel272
Question
hate to bring this thread back up but got another questtion b4 i sit this motor in here i was told this motor came out of a 98 but idk bout that it came out of a 93 accord wen i got it but i got 2 wires comin out of the crank i got a red wire and a green wire does anyone kno which ones wich crank sensor and the vtec pressure switch....?
Old 03-24-2012, 10:18 AM   #19
GhostAccord
If it were a 98 F series it would be an F23A1. If it is an 96-97 OBD2 F22B1 there should be 4 wires coming from under the timing cover.
WHT & BLU - CKP sensor and RED & GRN - TDC sensor. Sounds like your are missing the wires for CKP, maybe the last swap was using an OBD1 distributor. It houses all three sensors (TDC, CKP & CYP) just like the F22A1-6 does.
The OBD2 F22B1 does not use a VTEC pressure sensor. If someone was to put and OBD1 VTM on there. It would be part of the VTEC valve assembly on the head.
MR Thread
Old 03-25-2012, 12:20 AM   #20
axel272
so what would i do to wire up the vtec on it if it was obd1 or2 and what should i do bout the wires comin off the crank??
f22a1 , f22b1 , swap
