Old 03-31-2017, 03:26 AM   #1
Cragelarson83
Cragelarson83 is cool... so far.
Question Raspy exhaust sound after header install
I just installed my DNA header...before everyone says that DNA headers are crap..I'm on a super tight budget and couldn't find a a4 exhaust manifold at any junk yards around me and no luck on Craigslist... All i have done to the motor is short ram intake. My exhaust is oem. Before installing the header i soaked every nut and bolt in PB blaster 3 times. Every thing came off without any issues. When installing the furthest most left exhaust manifold bolt broke in the head. Every other bolt is fine and tight. I used copper gasket spray and used a REM flex gasket between the header and downpipe without the copper gasket spray. Every other surface had the spray on it. Hopefully within the next couple months I'm going to put 2.5" piping with I'm thinking a magnaflow muffler. I was quoted this setup for $350. I don't mind saving a little more to eliminate any and all raspiness. Any ideas or suggestions are welcomed. I do plan on upgrading the header eventually. Hopefully sooner then later. Thank you in advance for your help.
Cragelarson83 is offline   Reply With Quote
Old 03-31-2017, 05:08 AM   #2
Grumpys93
Once you put a resonator in your system it should get rid of most if not all of the rasp.
~Nick~
Old 03-31-2017, 06:30 AM   #3
kseriescivic
kseriescivic is cool... so far.
Vibrant streetpower muffler
https://www.amazon.com/Vibrant-1146-.../dp/B001804VDS
Vibrant ultra quiet resonator
https://www.amazon.com/Vibrant-1141-.../dp/B000E3VHWI
https://youtu.be/Ydv6BXQkk1s
That's what I'm going to get with 2.25 or 2.5 piping
kseriescivic is offline   Reply With Quote
Old 04-01-2017, 10:15 PM   #4
GTRON
GTRON is cool... so far.
I have an eBay exhuast, with a magnaflow high-flow cat, and muffler, and I had rasp. Welding on a long red glass pack got rid of the rasp, and made the exhaust sound warmer.
If I were to do it again I would buy a OBX header, and a Yonaka exhaust.
I'm faster then a prius
GTRON is offline   Reply With Quote
Old 04-02-2017, 12:11 AM   #5
kseriescivic
I thought about the yonaka exhaust but for close to the same amount of money i can have a custom vibrant exhaust...not a knock off apexi ws2. Also the yonaka will probably develop rasp sooner from the muffler and resonator deteriorating.
Just remember OP, you pay for what you get. If the exhaust you choose sounds good...what about in a year or two. If it sounds like ass after a while of being on the car, that defeats the purpose of buying that exhaust.
My 2012 civic si has a full race 3in catless DP and full race 3in catback. 20k+ miles later it still sounds DEEP and no rasp...just saying
Old 04-02-2017, 04:58 PM   #6
Corweena
Corweena is cool... so far.
a lot of people have issues with Yonaka quality going to sh*t at around 2 years. That's what you get for buying a cheap replica part. Risk of the quality sucking. Better off just buying a quality muffler the first time, even if it is used. There are lots of options:
Magnaflow
Apexi WS2
Greddy Evo
Greddy SP
Thermal R&D
Tanabe Medalion
Vibrant Street Power
Corweena is offline   Reply With Quote
Old 04-02-2017, 06:54 PM   #7
GTRON
I didn't know that it was a knock-off Apexi Ws2, haha. I haven't owned a Yonaka anything before, I have a friend (BreckAConner) that has that on his Cb7, and I really liked how it sounded. I can't comment on the durability though, LOL.
How much would a similar Vibrant set-up cost?
Old 04-08-2017, 09:36 PM   #8
wagon-r
wagon-r seems to have made some friends! wagon-r seems to have made some friends!
Magnaflow
Apexi WS2
Greddy Evo
Greddy SP
Thermal R&D
Tanabe Medalion
I tried several mufflers in my build to quiet down the drone at cruise without losing power. The best, by far - and the cheapest - was a Ford Mustang GT OEM muffler. A lot of the GT buyers replace their mufflers soon after they buy the vehicle, so you can get an OEM GT muffler for $40-$50 with only a couple hundred miles on it. It (along with a resonator) eliminated the drone at cruise, but it opens up at higher rpm. Nice sound, little power loss. Just be aware that it is 2.5" inlet and outlet. And make sure you get one from the newer GTs with 400 hp.
wagon-r is offline   Reply With Quote
Old 04-13-2017, 03:31 AM   #9
Cragelarson83
Wow i didn't even know i had so many replies. I need to get notifications... I feel like a idiot...lol... So when i was installing my aluminum rear lca's i hit my muffler with the breaker bar to see how bad the muffler was and it literally broke off of the exhaust pipe....guess it was real bad... I also developed a leak on the downpipe to to my stupidity installing the gasket. I tried to tighten the bolts a little more and snapped one off. I decided to leave the exhaust to the exhaust specialists. So i got quoted $250 to fix the header. They said that they won't do anything without fixing the snapped bolt in the head. That combined with the other snapped bolt on the downpipe and having to notch the cross member to make the header fit right is gonna cost just as much as buying a higher quality header. Lesson learned... Thanks to everyone that replied. I'm gonna look in to the mustang oem exhaust. I'm definitely gonna use a resonator if i go with magnaflow. Also my goal is better gas mileage and a little more get up.
Old 04-13-2017, 07:26 PM   #10
NinetiesBabyCB7
NinetiesBabyCB7 is cool... so far.
get a longer resonator, im 2.25" piping, 26" MBRP resonator, magnaflw hiflow cat, dc muffler, mugen header/downpipe..super deep note sound, no rasp or buzz or any rice burner crap..im also h22..custom exhaust is the way to go IMO
NinetiesBabyCB7 is offline   Reply With Quote
Old 04-22-2017, 03:31 PM   #11
Cragelarson83
I just got my car back from the exhaust shop. They fixed the header and notched the cross member to give the downpipe more clearance. They cut the back of my cat off, installed a 24" resonator, 2.25 exhaust tubing, magnaflow muffler and a 2.5 exhaust tip. I didn't want any chrome on the tip so they painted it cast color and heat treated it for free. I'm super happy with the sound. Its not loud at all. Its got a deep rumble with no rasp and looks amazing.
Old 04-22-2017, 03:47 PM   #12
GTRON
That sounds exactly like what I did to mine!
I still have a magnaflow cat though.
Can we get some exhaust sound videos?
Old 04-22-2017, 06:22 PM   #13
Cragelarson83
Yes you can. I just need to import them to photo bucket. Is there an easier way?
Old 04-22-2017, 06:44 PM   #14
PakaloloHonda
PakaloloHonda is cool... so far.
Send a message via AIM to PakaloloHonda Send a message via Yahoo to PakaloloHonda
Photobucket is easy ... fast ... I dunno about videos tho
I'd love to know what you spent, (if you don't mind me asking) I'm about to get rid of my magnaflow muff and replace the TWO resonators ...
PakaloloHonda is offline   Reply With Quote
Old 04-22-2017, 07:19 PM   #15
Cragelarson83
I spent $560 i paid cash so no tax. The bends are all smooth. Like i said they notched my cross member to make the cheap dna header fit. They had to fix a broke stud inn my head. Actually they replaced all the studs since i always use this shop. I also broke a bolt that connected my header to the downpipe. They cut the back of the cat tip improve the flow. They used oem gaskets. I was gonna go with 2.5" piping but I'm not trying to build this motor. I'm shooting for a mild build to increase gas mileage and give it a little more uuummph. The tip ran me $28. Also like i said earlier i don't want anything flashy so i had the tip painted and heattreated. The exhaust would have only ran me 80 but since they had to fix that header it increased the price quite a bit. I hope this helps you and I would recommend this setup for anybody that is looking for a deep tone with no raspiness what so ever and definitely improve flow.
Old 04-24-2017, 11:33 PM   #16
Cragelarson83
https://youtu.be/C5D_gCICKwY
Check out the link...more pics and videos to come. Lmk what you all think
Old 04-24-2017, 11:41 PM   #17
GTRON
Sounds really similar to mine! Why did you go with a 2.25" though?
I had a stud break on me too, and had to get my crossmember notched (wish I would have done that myself).
Old 04-25-2017, 11:12 PM   #18
Cragelarson83
I'm not going for a huge build. I mainly want better gas mileage. All the bends are real smooth. Plus 2.5 will have more rasp. I just wanted a deep tone with a lot better flow. Originally i thought about 2.5... All of my next performance mods will be mild. I have a a6 motor and tranny in my garage so I'll probably just do the a6 upgrades. My fuel pump is starting to go so I'm not sure what I'll do there but that's another thread i need to search for. I'm curious on why you asked about going with 2.25 though. I like to pick people's brains...lol. I have read a lot on it and for the most part for what my plans are 2.25 seamed like the best option.
Old 04-26-2017, 09:15 AM   #19
Cragelarson83
How do I change the title of this thread to curing a raspy exhaust or what I did to get a deep good exhaust tone on my f22a1
Old 04-26-2017, 12:59 PM   #20
deevergote
Don't call me dude.
I can change it for you. What exactly do you want the title to be?
As for fuel economy, increasing your engine's ability to breathe will actually DECREASE fuel economy in most cases. Greater airflow in and out of the engine will likely result in a greater oxygen content in your air/fuel mixture. The ECU will see this via the o2 sensor, and send more fuel to compensate. The best way to ensure the best fuel economy is to leave it completely stock, and keep the engine in its best running condition.
You CAN gain fuel economy with a custom ECU tune, but even that can be iffy (especially since the PT3 and PT6 ECUs are tuned quite well already).
2.5" piping is quite large for an F22A that is not going to be pumping out significant horsepower. That will raise your powerband a bit, forcing you to rev higher to use your engine's power. This will also contribute to a decrease in fuel economy.
dna header , f22a1 , oem exhaust , raspiness
