Where is ______?
    Where is ______?
    I have a list of sensors and what not and where they are found.
    ABS Control Unit (Coupe and Sedan): Right side of trunk, behind wheel well
    ABS Control Unit (Wagon): Behind Right side of rear seat
    ABS Modulator Solenoid Unit: Right rear corner of engine compartment, near under-hood fuse/relay box
    ABS Motor: Right front of engine compartment, below battery
    ABS Motor Relay: In under-hood ABS fuse/relay box
    ABS Pressure Switch: Right front of engine compartment, below battery
    A/C Compressor Clutch: Lower left front of engine, in A/C compressor assembly
    A/C Compressor Clutch Relay: Left front corner of engine compartment, on inner fender panel
    A/C Diode: Left front corner of engine compartment, taped to harness
    A/C Pressure Switch (Dual): Left front of engine compartment, behind headlight
    A/C Thermo Switch: Behind right side of dash, on A/C evaporator
    Alternator: Lower left front of engine
    Automatic Transmission Control Unit: On right front of floor, below carpet
    Auxiliary Fuse Holder: On left kick panel, on right of under-dash fuse/relay box
    Back-up Lights Switch: Center of engine compartment, on transmission
    Blower Motor: Below right side of dash, in blower assembly
    Blower Motor Relay: In under-dash fuse/relay box
    Blower Motor Resistors: Below right side of dash, in blower assembly
    Brake Fluid Level Switch: Left rear corner of engine compartment, in brake fluid reservoir cap
    Brake Light Switch: Below left side of dash, on brake pedal support
    Brake Light Sensor (Inner): Left rear of cargo area, in front of taillight
    Brake Light Sensor (Outer): Right rear of cargo area
    Bypass Solenoid: In engine compartment, below intake manifold
    Chime: Behind left side of dash
    Cigarette Lighter Relay: Behind left side of dash, near kick panel
    Clutch Interlock Switch: Behind left side of dash, on clutch pedal support
    Clutch Switch: Behind left side of dash, on clutch pedal support
    Condenser Fan Motor: Left front of engine compartment, behind radiator
    Condenser Fan Relay: Left front corner of engine compartment, on inner fender panel
    Coolant Temperature Gauge Sender: Right front of engine, below distributor assembly
    Coolant Temperature Sensor (TW): Right side of engine, below distributor assembly
    Coolant Temperature Switch A: Right rear of engine, in coolant inlet
    Coolant Temperature Switch B: Right side of engine, in coolant outlet
    Countershaft Speed Pulser: Right rear of engine compartment, on transmission
    Cruise Control Actuator: Left side of engine compartment, behind headlight
    Cruise Control Unit: Behind left side of dash
    Daytime Running Lights Control Unit: Behind left side of dash, next to kick panel
    Dimmer Relay: In under-hood fuse/relay box
    Disarm/Beep Switch: On lower left dash panel
    Distributor Assembly: Right side of engine
    Driver's Door Lock Switch Actuator: Inside lower rear of driver's door
    Driver's Door Switch: In rear of driver's door jamb
    Driver's Power Door Lock Actuator: Inside lower rear of driver's door
    Driver's Power Window Motor: Inside lower front of driver's door
    EGR Valve Lift Sensor: Top right of engine, forward of throttle body
    Electric Load Detector Unit (ELD): In under-hood fuse/relay box
    Electronic Air Control Valve (EACV): Top center of engine
    Emission Control Box: Right rear of engine competent
    Engine Oil Pressure Switch: Center rear of engine, above oil filter
    Engine Mount Control Unit: Behind left side of dash
    Engine Mount Control Solenoid Valve: Center rear of engine compartment, behind intake assembly
    Fan Timer Unit: Behind Left side of dash
    Front ABS Fail Safe Relay (Coupe and Sedan): Right side of trunk, behind wheel well
    Front ABS Fail Safe Relay (Wagon): Behind right side of rear seat
    Fuel Injectors: Top center of engine, at each intake port
    Fuel Injector Resistors: Left side of engine compartment, forward of strut tower
    Fuel Pump: Under maintenance access cover, below rear seat
    Fuel Tank Unit: Under maintenance access cover, behind rear seat
    Headlight Relay: In under-hood fuse/relay box
    Heater Mode Control Motor: Behind center of dash, on heater assembly
    Horn Relay: Behind left side of dash
    Ignition Coil: Right rear of engine, behind distributor
    Ignition Key Switch: Upper right side of steering column, on ignition switch assembly
    Ignition Switch: Upper left side of steering column
    In-Line Fuse Holder: Taped to harness, behind left side of dash
    Intake Air Control Solenoid Valve: Right front corner of engine compartment, on inner fender panel
    Intake Air Temperature Sensor (TA): Left rear of engine, on intake manifold
    Integrated Control Unit: In under-dash fuse/relay box
    Interlock Control Unit: Behind left side of dash, near kick panel
    Junction Connector A: Ahead of left center pillar
    Junction Connector B: Below left side of dash, near center console
    Key Interlock Solenoid: Upper right side of steering column, on ignition switch assembly
    Key Interlock Switch: Upper right side of steering column, on ignition switch assembly
    Keyless Entry Control Unit: Under driver's seat
    Left Front ABS Speed Sensor: On left front suspension knuckle
    Left Rear ABS Speed Sensor: On left rear suspension knuckle
    Left Brake Light Sensor: Left rear corner of trunk, on taillight assembly
    Left Horn: Left front of car, behind bumper
    Left Rear Door Switch: In rear of left rear door jamb
    Left Rear Power Door Lock Actuator: Inside rear of left rear door
    Left Rear Power Window Motor: Inside middle rear of left rear door
    Lock-up Control Solenoid Valves: Right front of engine compartment, on transmission
    Mainshaft Speed Pulser: Right front of engine compartment, on transmission
    Moonroof "Close" Relay: Below left side of dash, above under-dash fuse/relay box
    Moonroof "Open" Relay: Below left side of dash, above under-dash fuse/relay box
    Moonroof Motor: Center rear of roof, above headliner
    Oxygen Sensor (DX,LX): Center front of engine, in exhaust manifold
    Oxygen Sensor (EX): Under center rear of engine compartment, in exhaust pipe
    Parking Brake Switch: In console, at base of parking brake
    PGM-FI Electronic Control Unit: On right front floor, below carpet
    PGM-FI Main Relay: Behind left side of dash
    Power Antenna Motor (Coupe and Sedan): Left side of trunk, behind wheel well
    Power Antenna Motor (Wagon): Left rear of cargo area
    Power Door Lock Control Unit (Coupe and Sedan): Front of driver's door
    Power Door Lock Control Unit (Wagon): Under drivers' seat
    Power Steering Switch: Lower left rear of engine compartment
    Power Window Relay: In under-hood fuse/relay box
    Radiator Fan Motor: Right front of engine compartment, behind radiator
    Radiator Fan Relay: In under-hood fuse/relay box
    Radio Noise Condenser: Top left side of rear tray
    Rear ABS Fail Safe Relay (Coupe and Sedan): Right side of trunk, behind wheel well
    Rear ABS Fail Safe Relay (Wagon): Behind right side of rear seat
    Rear Window Defogger Relay: In under-dash fuse/relay box
    Rear Window Washer Motor: Behind lower left corner of front bumper
    Rear Window Wiper Motor: Center of tailgate
    Recirculation Control Motor: Below right side of dash, on blower assembly
    Remote Control Key Recharger: Upper right side of steering column
    Right Brake Light Sensor: Right rear corner of trunk, on taillight assembly
    Right Front ABS Speed Sensor: On right front suspension knuckle
    Right Front Door Key Cylinder Switch: Upper rear of right front door
    Right Front Door Switch: In rear if right front door jamb
    Right Front Power Door Lock Actuator: Inside lower rear of right front door
    Right Front Power Window Motor: Inside lower front of right front door
    Right Horn: Right front of car, behind bumper
    Right Rear ABS Speed Sensor: On right rear suspension knuckle
    Right Rear Door Switch: In rear of right rear door jamb
    Right Rear Power Door Lock Actuator: Inside rear of right rear door
    Right Rear Power Window Motor: Inside middle rear of right rear door
    Seat Belt Switch: Inside driver's seat belt buckle
    Security Control Unit: Behind left side of dash
    Security Flasher Relay: Behind left side of dash
    Service Check Connector (C444 - 2-BLU): Below right side of dash, at kick panel
    Shift Control Solenoid Valves: Lower right front of engine compartment, on transmission
    Shift Lever Position Switch: Under left side of console, at base of gear selector
    Shift Lock Solenoid: Under right side of console, at base of gear selector
    SRS Control Unit: Below center of dash, below heater assembly
    Starter: Right side of engine above transmission
    Starter Cut Relay 1: Below left side of dash
    Starter Cut Relay 2: Below left side of dash
    Starter Solenoid: Right side of engine, above transmission
    Tailgate Latch Assembly: Center of tailgate
    Throttle Angle Sensor: Right rear of engine, behind throttle body assembly
    Trailer Lighting Connector (C618 - 8-GRY) (Wagon): Left rear of cargo area, in spare tire compartment
    Trailer Lighting Connector (C717 - 6-BLU) (Coupe and Sedan): Left side of trunk, top rear corner
    Trunk Latch Switch: Rear of trunk lid, on trunk latch assembly
    Turn Signal/Hazard Relay: In under-dash fuse/relay box
    Under-dash Fuse/Relay Box: On left kick panel
    Under-hood ABS Fuse/Relay Box: Right side of engine compartment, forward of strut tower
    Vehicle Speed Sensor: Right rear of transmission
    Windshield Washer Motor (Coupe and Sedan): Behind lower left corner of bumper
    Windshield Washer Motor (Wagon): Behind lower left corner of front bumper
    Windshield Wiper Motor: Left rear corner of engine compartment, under air scoop
    Wiper Relay: Right rear corner of engine compartment, behind under-hood fuse box
    Under-hood Fuse/Relay Box: Right rear corner of engine compartment, behind strut tower
    Hope this helps someone.
    SuddenCb7 - 1992 Honda Accord EX Coupe
    awesome. stickied.
      Sweet thanx mike I have been trying to get something sticked.
        Great list man, this can come in handy!!!
        1990 Accord Lx F22a1(Daily) SOLD - will be missed
        1990 Prelude Si B21a1 (Fun car!)
          dude u rock..thank you SO much for taking the time to list everything out..this is seriously gonna help a lotta people out..and thank you mike for making it sticky status..pe@ce love and chicken grease from the middle east..
            Wow your thankful.
              where is the " main relay " and does someone have a pic
              Well since i dont have a pic of my REAL CAR this will have to do
                damn he even made this list in alphabetical order,
                thanks!
                .............................-----------------93 Ex Coupe[/COLOR]-----------------
                My CD7
                  WOW!Nice job!
                  My whips!
                  97 eliteS 50cc sold
                  90 CB coupe lx h22 turbo(ITS GONE!)
                  93 CB 4dr ex/se
                  85 Hilux 4x4(chevy 350)traded
                  80 Hilux 2wd still got it
                  73 Opel GT garage queen
                  92 cx hatch b16a ran into the ground
                  93 si hatch b16a type-r trans parted out
                  92 dx hatch fully built GSR "huge" fmi sold
                  09 4dr 4x4 Tacoma small lift daily beater
                  93 dx hatch b16a2 (old team rice car) was free!
                    awesome man, thanks.
                      Awesome, It's gonna be real Sticky
                      Your car is faster, I'm the better driver
                      Greetz Erwin
                      My last ride
                      Shakes and Fidget - The Game
                        I guess if everyone could pitch in and take pictures of the exact location of parts listed, that would be real cool!
                          Mate thats what you call A CB7 TUNER
                          Tommy Gun.... Gunning It all dA waY...
                            wow talk about back from the dead...still have to finish reading all the locations..lol
                              ok this was good info. now can someone tell me where are all the grounds located and what ground does that supply to.
                              problem is. theres no power to
                              main relay
                              ecu
                              distributor
                              miss my turbo cb7
                              moved onto volvos. dont know how that happened, just did
