93 Accord race car Build/Questions thread
    Originally posted by ukemike View Post
    Are y'all going to make it to Thunderhill in September? I know it's a long shot with all that damage you took, but we'll be there in our 1991 Accord. It'd be extra fun to have two F22A1 CB7 Accords out there at the same time.
    Not goign to make it to Thunderhill, too far I wish I was going to race with you guys though.
    What about Sonoma in December? I'm going to be there with my other team (GoPro). You guys will hate me, but its a BMW E28
      Also I'm looking for a lower timing belt cover. Does anyone have one? After getting dirt in the timing belt and slipping timing TWICE, I'm going to to whatever I can to protect the belt from dirt.
        Last weekend, removed the smashed parts and picked up junkyard fender, hood, bumper, core support, alternator for $110
          Wish you luck at Sears Point in December. I have my doubts that we will be doing that one. I for one will not have the money. Thunderhill is probably our last hurrah until my wife is out of gradschool and has a job again. Racing, even crap-car racing, is not for the poor.
          1993 Accord Lemons Race Car, "SpaceEx Starship"
          M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
            I think I saw you guys on Roadkill ep42. The Rotsun!
              Holy crap that is the Accord on Roadkill..
                Love it. As another option, I did 90-93 DA Integra front upper control arms. Don't have to deal with the stupid adjustable cheap crap, and I got -3 degrees camber and +4 degrees caster. $75 shipped from Rock Auto, use Beck-Arnley stuff. Re-used the Accord Anchor bolts with the DA UCA's.
                '98 Prelude resto/mod thread
                  what did you mean you used da upper control arms?
                    Ahhh thanks! That's me on the roof at https://youtu.be/gbcyi_rGdjU?t=1617
                    lol
                    As for the control arms, I wanted the adjustability, even if they are cheap. I have 3.75 degrees in the front right now and that's about perfect, I think 3 degrees would be too little.
                    With tack welding the balljoints on, the Civic ebay arms worked great
                      Roadkill episode 42 @ 26:56 and just before that you can see the car on the track. Love the build man. Can't wait to do this with my 90 DX coupe next year. Thanks for posting the cage pictures. Helps a lot.
                        THIS THREAD
                        Love it.
                        Someday when I'm rich I hope to get a CB7 on the track for Lemons. Gingerman and Autobahn are where I'm most likely to turn up. In the mean time I'll just keep living vicariously through you guys. Thanks for keeping up the thread!
                          Love this build! Nice to see you guys on roadkill! Its funny how they couldn't even do 50 laps but you managed 200+ laps. Nice going!��
                            aventari,
                            Are you going to be at Sonoma in February??? CB7 Accord showdown?
                              I will have to check out Roadkill. Not sure what that is but it sounds awesome! You and your team have done a lot of work to the CB. I really commend you on all the work that you guys accomplished.
                              Thank the lord no one was injured in the crash. 110 for all that from the junkyard is not that bad at all.
                              The yards around my way really kill you on price. I try and haggle and if i am unsuccessful, I leave.
                                Hey all, so it's time to update the thread, I'm racing in June!
                                Chumpcar, Auto Club Speedway June 4-5
                                http://chumpcar.com/
                                Since the last race, I've mostly just been fixing the smashed up parts and the bent frame from the crash
                                Here's the view from the car my bro hit
                                https://www.facebook.com/faustest/vi...5662094195459/
                                So since then, I got the frame straightened ($370), got the car aligned again, gutted the new hood, and put all the new body parts back together.
                                This last weekend my friend and I
                                Installed and automatic fire suppression syste-- the 2.25 liter system here (http://www.racingfiresystems.com/Rac...d_Systems.html)
                                Fabricated a center console panel for fire system handle
                                Welded front motor mount solid as the urethane inserts I made had disitegrated.
                                Replaced cracked IAB vacuum line
                                Bled brakes and clutch with Motul RBF600
                                Welded front upper ball joints to Ebay adjustable arms, as the tiny bolts that hold the joints are quite flimsy
                                And added killswitch cable pull to center console
                                I didn't take enough pics but here's the fire system. Two nozzles, one pointed at the engine and one pointed at the drivers dick
                                I got this underdrive pulley for $38 on Ebay, it came dented in the mail so I filed the dented part back away from the belt. I'm taking it to the machine shop to have it balanced tomorrow.
                                Welding motor mount solid:
                                This plate is overkill, I should've just made both sides like the first strip of metal
                                I'm going to be working on the car non stop until June and I'll try to keep this thread updated.
                                aventari,
                                I didn't make it, how was your race??
